Hope to get it all fitted on saturday.
Posted 26 May 2011 - 07:40 PM
Posted 27 May 2011 - 01:31 PM
Posted 27 May 2011 - 05:52 PM
Posted 27 May 2011 - 06:08 PM
Posted 28 May 2011 - 11:30 PM
Posted 29 May 2011 - 07:49 PM
Thanks Chris.... Yeah..I was on the Thistle Run this weekend. 300 miles of fast driving. And your right, it sounds much better now. Once the revs are up it gets a lovely "bark". The guys at Maniflow said this is the best setup for my engine spec. And to be honnest I dont know enough about it. So just went with what they said. Ive had a look at the Yellow bible and its all a bit over my head. I understand the flow and pulse stuff in the LCB but then it all gets a bit to much for me when the bore size and lenght of pipe stuff kicks in.havent a clue at the change in cam... probably something to do with the change in back pressure... dont worry tho... youll find the exhaust still needs to bed in and line itself with carbon and soot etc... mine sounded uber quiet when i stuck it on... even tho mine was the single box... but after about 100 miles it really started to clear its throat nicely:)
not sure why they recommended the double box to you??? i was always under the impression that the single was the better performing???
chris
Posted 02 June 2011 - 05:15 PM
Edited by AndyMiniMad., 02 June 2011 - 05:40 PM.
Posted 02 June 2011 - 05:45 PM
Edit.....2000 grit NOT 200......If you use 200 grit on your paint it will make you cry.....
Posted 03 June 2011 - 10:58 AM
Posted 03 June 2011 - 10:39 PM
is that thistle run plaque a sticker or magnetic??? thats pretty cool...
nice job with the polishing:) has come out real nice indeed...
Edited by AndyMiniMad., 03 June 2011 - 10:40 PM.
Posted 06 June 2011 - 09:38 AM
Posted 06 June 2011 - 10:40 AM
Posted 06 June 2011 - 11:00 AM
Really inspiring to do something similar engine and box wise.. Looks like you did a great job
Posted 08 June 2011 - 12:08 PM
Edited by AndyMiniMad., 08 June 2011 - 12:08 PM.
Posted 08 June 2011 - 03:57 PM
