I decided early on in March when I started on build 2 that I would attempt to run all the cables (battery) and wiring, petrol lines and brake pipes inside the shell so part of the build is currently under way. I am trying to allow for seats, centre console etc whilst laying the pipes and cables so it is a bit hit and miss at the moment, everytime I fix a pipe down I have to move it to allow for the seats or something.
As you can see after dealing with the outside of the shell I moved inside with a little help from my 14 year old daughter (who thinks the car is her’s when it is finished !)., We rub down all internal rust off the floors, roof and pillars, treated with 1 litre of blue hammerite and then I laid a roll or two or three of soundproofing self adhesive mat like dynamat (but cheaper), which should give a little extra strength to the thinner panels especially the floor and rear panels.
2 gallons of waxoly has been poured sprayed and injected into every space I can find include door pillars, roof box sections and rear wheel arches to fight off the rust for a little longer, I hope.
As the shell didn’t come with any doors I have used the doors from the first mini build which were in responsible nick just needing rubbing down, treating and some filling on the bottoms. Copious amounts of waxoyl was poured into the doors to hopefully stop the rusting from the inside out ?
The doors have now been painted satin black on the inward facing sides to match my colour scheme of greys and blacks with some orange to match to exterior colour thrown in for good measure (more in later months as the build progresses).
Edited by apjmini, 14 May 2011 - 10:30 AM.
