Year: 1998
Right - I carried out my first oil change on my Mini today. The previous owner had it done fairly regularly (looking back over the bills), but I think it might have been quite a long time since the last one because the oil was pretty black. Now that the cones are done, I thought I had better do an engine oil and filter change.
This is what I found when I drained the oil
Does anyone have an idea what these pieces of metal are? They are quite thin, but fairly strong - they can't be bent with your fingers, although they show signs of being mangled on their way to the sump. If it is any help, they aren't magnetic, and appear to have the colour of brass (as I know the photo doesn't show that too well).
Now, she does jump out of second every so often - usually almost always after changing down from third, or if you go through a particularly big pot hole. Could the bits of metal be the cause of that?
So, any ideas? Whatever it is, it is unlikely to be good - and highly likely to be expensive
