Hi everyone,
Possibly a simple problem, but is there a way of identifying which type of carb I have? There doesn't appear to be any markings anywhere that make it obvious whether its a HIF44 etc??
Cheers,
Neil.
Identifying Su Carb Model
all4sreturns
, May 27 2010 08:52 AM
6 replies to this topic
Posted 27 May 2010 - 08:52 AM
Posted 27 May 2010 - 08:53 AM
Measure the diameter of the choke ( this is the big hole through the middle ) this will give you the size, and then a picture would have helped to tell you what sort, H, HS, HIF etc etc
Posted 27 May 2010 - 09:11 AM
If the fuel float bowl is separate and to one side of the carb is is a HS type, if the float bowl is integral then it's HIF type.
1 1/4" = HS2
1 1/2" = HS4 or HIF38
1 3/4" = HS6 or HIF44
Bold carbs are most common, that's if yours is an SU...
1 1/4" = HS2
Posted 27 May 2010 - 09:16 AM
I think on the HIF38 and HIF44 there is a difference with the rear of the carb were the filter bolts on from this you can tell if its 38 or a 44, but can't find a picture to show it.
Posted 27 May 2010 - 12:09 PM
I've been having this problem recently. I keep seeing contrasting things on whether I've got a HIF38 or HIF44.
Found this page which was quite helpful. The top picture is the HIF38 and the bottom is the HIF44.
Posted 28 May 2010 - 11:44 AM
Thanks everybody.
I will stick a picture on here to aid identification!
Posted 01 June 2010 - 07:44 AM
38 = 1.5" diameter ............ 44 = 1.75" diameter
