well I am telling you from experiance and all 20yrs of it, now your engine your choice, but, rings do pass pistons especially when clocking 6,000 rpm. sorry to give you bad news but It requires a rebuild and that will inc new pistons
dave
Oil In Cylinders, And Pitted Piston?
MiniLandy
, May 26 2010 01:21 PM
20 replies to this topic
#16
Posted 27 May 2010 - 04:04 PM
#17
Posted 27 May 2010 - 04:07 PM
Sorry dave...
Maybe I'll know as much as you in 5 years...
Edited by miniobsessed, 27 May 2010 - 04:22 PM.
#18
Posted 07 September 2010 - 05:13 PM
My oh my, i forgot about this thread!
Sorry minidaves, but i dropped this engine in my mini, and have covered a couple of thousand miles since. In fact, it made it to hunstanton and back, cruising at about 75 on the dual carriageway behind a modern car, for an hour or so (friend's 107) with four people in it. And buckets and spades.
So, not rings then
Most likely, as was said by miniobsessed, was a foreign body of some ilk. Or has been suggested by a knowledgable mini builder, the tip of a spark pug that broke off.
Cheers!
So, not rings then
Cheers!
#19
Posted 07 September 2010 - 06:34 PM
I have to say that I think there's been something in the pitted cylinder, and I wouldn't worry about it!
The oily cylinder i believe to be Oil from the head, as suggested above check for wear and replace, however i would as par of the course, replace the vlave stem seals anyway.
#20
Posted 08 September 2010 - 06:17 PM
My thoughts exactly
However, when i checked and stripped the head, i only got 4 stem seals in the head kit. Sooo i only changed the exhausts.
As a results, it still smokes on startup.
However, if you read my project page, you'll see that i have another head, which is going to get properly overhauled, and then bolted on with a 266 cam and twin HS2's
#21
Posted 08 September 2010 - 08:04 PM
The payen kits come with all 8 IIRC.
If you get a kit with just 4 then you need to change the inlet seals.
