want to check out the breaks with the wheels off and still haven't jacked the mini up since owning it!!
Much Love
Ben
Posted 24 May 2010 - 02:57 PM
Posted 24 May 2010 - 02:58 PM
Posted 24 May 2010 - 03:01 PM
Posted 24 May 2010 - 03:16 PM
Posted 24 May 2010 - 07:11 PM
Under the subframe, chock the rear wheels and put the jack under the subframe.
Use axle stands once the cars up to make sure it doesn't fall off.
Dave
Posted 24 May 2010 - 08:45 PM
Posted 24 May 2010 - 10:10 PM
Posted 24 May 2010 - 11:00 PM
Posted 24 May 2010 - 11:27 PM
how do they work???
and what are you lifting it on?? looks like the sump from that picture which is a big no no
Posted 24 May 2010 - 11:39 PM
how do they work???
Looks like it hooks under the front subframe rail good idea, if not over designed for the job.
I just use a two foot length of wood and jack up on that front stubframe rail or some times sump depending on what wood i got laying around if its a nice flat wide peice i dont mind jacking up on sump as it wont hurt it its all about dispersing load with the wood. Then i use some axle stands/bricks depending on whats avalable where the floor meets bulk head as theres a good few layers of metal there to help give strngth still puts abit of a dint in floor pan tho if i use axle stands.
Best ive seen is the mini on four axle stands but there were two long lengths of timber under the floors and the timber was sat on the stands so the lengths of wood dispresed the load well and the whole car could be raised veryy high off the ground good for working under.
Posted 25 May 2010 - 06:36 AM
Posted 25 May 2010 - 07:34 AM
Posted 25 May 2010 - 12:20 PM
i found a good idea at halford yesterday there axel stands place them where you wont then you wind them up and the car goes up from these thought it was a good idea
clicky
