What Size Spark Plug Tool ?
8 replies to this topic
#1 maston
maston
  • 126 posts
Posted 24 May 2010 - 02:05 PM
Hi there,
I have an Austin mini City E 998cc 1989 and am trying to put new plugs in.
The spark plug tool I have is too small, could you please tell me what size the plugs are and what size tool I need ?
Many Thanks
Regards
Ian
#2 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 24 May 2010 - 02:49 PM
Hi there,
Many Thanks
Regards
Ian
21 mm
#3 mgb1978
mgb1978
  • 108 posts
Posted 24 May 2010 - 03:05 PM
As danie said the socket size is 21mm, But the spark plugs themselves are called 14mm plugs
If you are ever buying a compression tester or gunsons colortune, etc then you will need a 14mm one.
#4 maston
maston
  • 126 posts
Posted 24 May 2010 - 03:06 PM
Hi there,
Many Thanks
Regards
Ian
21 mm
Many Thanks
Ian
#5 samsfern
samsfern
  • 5,243 posts
Posted 24 May 2010 - 03:07 PM
13/16" is the one you should use...
#6 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 24 May 2010 - 03:10 PM
thats 20.63mm, 21 is close enough!
#7 maston
maston
  • 126 posts
Posted 25 May 2010 - 12:36 PM
Thanks everyone for your replies.
I have just bought a 21mm spark plug wrench but I'm not sure if I have the right drive ???
There are 1/2" or 3/8" drive ???
Many Thanks
Regards
Ian
#8 Ethel
  • 25,965 posts
Posted 25 May 2010 - 12:51 PM
Doesn't matter, as long as you have something that fits to turn it.
I'd opt for 1/2" if there's a choice - one size fits all toolkit for the road.
Many Thanks
Regards
Ian
#9 Pooky
Pooky
  • 5,691 posts
This relates to the size of the square peg on the ratchet you're using. Common sizes being 1/4" (small), 3/8" (medium) and 1/2" (large).
Measure the width across the flats on the square peg you click the socket onto to give you the size you need :)
