Polishing A Carb?
Posted 19 May 2010 - 08:22 AM
just a quicik one. ive been given a replacement carb by a mate and i want to know as ive got a few days ebfore its fitted. Whats the best way of polishing it up.
Dan
Posted 19 May 2010 - 08:26 AM
Posted 19 May 2010 - 08:27 AM
Posted 19 May 2010 - 08:30 AM
Posted 19 May 2010 - 08:32 AM
i dropped luke off came home and went straight upstairs, so did martin by what he said on monday
Posted 19 May 2010 - 08:36 AM
by the way would u pm me ur moblie no. because ive lost the sheet
cheers
Edited by LESTA MINI, 19 May 2010 - 08:37 AM.
Posted 19 May 2010 - 12:08 PM
Do not leap in with Brasso or other polishing compounds first. Treat this exactly as you would polishing/buffing paint that has debris or blemishes in it.
Start with wet/dry paper and sand the outside of the chamber. Start with something around 320 Grit. Then change to progressively finer media (600, 1000, 1500 or 2000). Rinse the vacuum chamber between each different media to remove any abrasives left on the surface. Once you have finished with the 2000 grit the chamber will look smooth but won't shine. At that point you can switch to a buffing wheel with compound on it. I would not use Brasso. I've had good luck with Simichrome which you should find in the U.K. as well. However, almost any quality polishing/buffing compound will work after sanding with 2000 grit. Work at a low speed. Do not use the Dremel, drill, or buffing wheel on high speed. If you do, you will introduce scuff marks. Start with a clean buff so there are no left over abrasives from a previous polishing job. Also, wash your hands often in the process.
This may sound like a lot of work. However, if you sand the chamber as I suggest working to finer and finer grits, the whole process will go faster and have better results than starting directly with compound on the vacuum chamber.
Posted 19 May 2010 - 02:01 PM
Be wary of using power tools, too much heat could distort it.
Posted 19 May 2010 - 10:58 PM
You don't know until you try.
Posted 19 May 2010 - 11:14 PM
Edited by rick.spi, 19 May 2010 - 11:17 PM.
Posted 20 May 2010 - 01:18 AM
Whats wrong with brasso i used it on this alloy switch plate.
My only reason for suggesting something other than Brasso is that Brasso contains ammonia for removing oxides from copper and brass. Ammonia is a base and when you use bases on aluminum and aluminum alloys they attack the surface a bit. In short, it just will make polishing a bit harder but that's not to say it won't work.
Posted 20 May 2010 - 08:05 AM
It will work but you will see it stained and dull in a few weeks.
Take the "long route" for a lasting job.
There are other aluminum products that do not contain ammonia. i dont recall any names but ask around in the stores
Posted 20 May 2010 - 12:27 PM
Fair Enougth if theres actual science to it, but my switch plate still looks same after like 4 months without polishing just dusting.
