Replacing Windscreen Seal ?
Posted 17 May 2010 - 03:43 PM
Is it hard to replace this seal? and will i need any special tool ? or is it just easier to get a garage to do it ?
Thanks again
Posted 17 May 2010 - 03:53 PM
Put rubber around the screen, bit of washing up liquid should help it on easier (but not to much else it'll move and slip around)
Insert cord into other side of the rubber
Then press screen into place
while your mates pressing said screen into place
start pealing the cord out from inside so the rubber laps over holding it into place
If you are not to sure on doing this your self. A garage shouldn't charge you to much to do it for you.
Posted 17 May 2010 - 03:54 PM
Posted 17 May 2010 - 04:51 PM
Thanks for the reply's
Posted 17 May 2010 - 04:57 PM
Posted 17 May 2010 - 05:10 PM
Im rebuilding at the moment and need to purchase a new windscreen rubber, is it worth buying the the wide one over the normal one?
Posted 17 May 2010 - 05:54 PM
Edited by cambiker71, 17 May 2010 - 05:54 PM.
Posted 17 May 2010 - 06:06 PM
but when was the last time you saw an MPI with the right amount of paint on it?
Posted 17 May 2010 - 07:03 PM
Posted 18 May 2010 - 12:10 AM
The MPI had a wider/bigger seal to make it more leak proof, maybe worth using one of those.
Hi,
I read somewhere that the windscreen glass is thicker and heavier in the MPI. Is the MPI seal still compatible with all other windscreens?
Ivan
Posted 18 May 2010 - 06:00 PM
Posted 18 May 2010 - 07:18 PM
oh cool, after I had posted this i found an FAQ on how to do it but its a little confusing, Im sure if i tried to do it it would make sense,also where could i buy one of these special tools?
Did you find the FAQ here?
http://www.theminifo...showtopic=10693
If any of that is unclear, feel free to ask. Having replaced glass in several cars (Mini and non-Mini) I can say there are some where the string method suggested by Timify works well. However, with the Mini, fit the rubber to the body opening, then use a plastic tool to pry the seal over the glass instead as detailed in the FAQ.
Since the FAQ was written someone suggested to me that K-Y Jelly of a similar personal lubricant works well on fitting the locking strip. Since that suggestion I've tried it in a couple of installations and it does work nicely.
Do buy or make the fillet installation tool. Putting the lock strip in without one is a difficult task. Most Mini suppliers should have the tool. They are also on eBay and you can make your own from a coat hanger if you copy the basic shape you'll see in pictures of the tool.
Posted 18 May 2010 - 07:31 PM
Posted 18 May 2010 - 07:37 PM
Still on the note of windscreen's. My 1986 city, would that have had the laminated glass and or the tempered glass, and also the narrow or wide seal. Need to order the bits up, but i don't have access to the original screen at the moment.
It would have had the 'Secursiv' branded non-tinted laminated glass and the narrow seal as standard.
(I know because I had a late 1985 Mini Mayfair and that had the same only being a Mayfair meant the glass was tinted).
Edited by taffy1967, 18 May 2010 - 07:38 PM.
