Air Box Mods
Posted 14 May 2010 - 07:34 PM
Posted 14 May 2010 - 07:40 PM
Posted 14 May 2010 - 07:47 PM
Just a heads up
Posted 14 May 2010 - 07:49 PM
Posted 14 May 2010 - 07:55 PM
got a 1989 mini 1000 with stage one kit and 12g295 head. its got a cone filter but its so loud and it is a sod getting it to run nice. been told i am better off with standard box rather than the cone filter.
Standard air box, K&N filter and drill a few holes around the bottom front edge an all should be fine. Probably more efficient than the cone aswell.
Posted 14 May 2010 - 08:00 PM
Like this: -
Although I still prefer the neatness of the K&N cone filter myself.
Posted 14 May 2010 - 08:03 PM
Posted 14 May 2010 - 11:14 PM
Posted 15 May 2010 - 12:18 AM
if you dont want the noise a k&n panel filter is a good option.
Edited by rick.spi, 15 May 2010 - 12:18 AM.
Posted 15 May 2010 - 07:50 PM
This is because with the cone filter it draws in air from the entire engine bay. Whereas the airbox option draws in air as it should have from the factory. Hope this helps.
Posted 15 May 2010 - 09:35 PM
I have found that the standard airbox with a K&N panel filter is much better than the cone filter.
You've got a point there, but once on the move there's one hell of a large amount of cold air rushing in through the front grille, so the cone K&N is still effective.
I've had mine fitted for about 12 years and after a recent rolling road tune there was no problem at all.
