Harness Bar
240 replies to this topic
#1 JonBetts
JonBetts
  • 298 posts
Posted 13 May 2010 - 03:35 PM
I wanted a harness bar for my own Mini so made one up to bolt to the rear aches, this raises the mounting point for the rear straps to a much safer position and more inline to where they would be mounted if I had a cage fitted. In my view this is better than just bolting them to the rear seat belt mounting points which really makes the straps sit at too low an angle and not directly inline with the back of the seat.
I have used 32mm CDS tube and laser cut 3mm brackets and sandwich plates, with guides for harness up to 3-inch wide and M10 fixings. I'm gonna make a few up to sell if anyone else is interested just drop me a PM or email me at [email protected] cost will be 32.50 plus delivery so not expensive. Seen some for a Saxo or something like that on Ebay for 80-quid!!
#2 JonBetts
JonBetts
  • 298 posts
Posted 14 May 2010 - 10:39 AM
Please note i can also make these with a single harness guide for use with 3-point harnesses or with the guides not welded on at all so you can position these yourself for one off applications.
I am also look at making them to go with a stadard bolt in cage which doesnt have a harness bar fitted. If you require one for this particular application please drop me a line.
#3 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 14 May 2010 - 10:42 AM
These look really good Jon! I have to bucket seats, no rear seats and my 3 point harnesses attachted to the rear seatbelt bolts. but this looks really good :) If i had a rear cage, would this bar still fit in it?
#4 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 14 May 2010 - 10:46 AM
Just a thought, how would my harness bolt into that bar?
#5 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 14 May 2010 - 10:47 AM
I'd like to see the one for a bolt in cage, would it still work with a diagonal brace fitted?
#6 JonBetts
JonBetts
  • 298 posts
Posted 14 May 2010 - 10:49 AM
Looking at making another bar for use with a cage although you may still be able to bolt this to the rear arch with the cage fitted but would need to see a picture of your arch. The harness can either be wrapped around the bar as in normal motorsport applications or I can install some 4mm tags to allow you to bolt the harness directly to the bar. Hope this helps.
#7 JonBetts
JonBetts
  • 298 posts
Posted 14 May 2010 - 10:53 AM
[/quote]
Still in the design stage, my main problem is the various cages that are currently in use so it may be a universal bar that attaches to the inner face of the rear arches rather than trying to link into the standard cage mounts. Should have something sorted next week.
#8 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 14 May 2010 - 11:00 AM
so i could just wrap it around the bar without bolting it in anywhere, but would it not unwrap? sorry im a bit knew to this, still learning :)
#9 JonBetts
JonBetts
  • 298 posts
Posted 14 May 2010 - 11:15 AM
You need to wrap them around in a particular manner, will post some pictures later and also some of a bar with a bolt on lug fitted. Off down the workshop shortly ;-)
#10 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 14 May 2010 - 11:46 AM
Cool, look forward to it :)
#11 JonBetts
JonBetts
  • 298 posts
Posted 14 May 2010 - 04:03 PM
First picture shows hw you ca wrap the harness round the bar either 3 or 4 point, its not fully secured in that picture as the strap needs to loop back thru but you get the idea. I have also done one today that you can bolt your harness directly to either using one of the readily available harness eye bolts or you could just bolt directly to the lug.
#12 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 14 May 2010 - 04:25 PM
That looks really good :bah: when i get some money together i'd happily get one from you :withstupid: where abouts are you based?
#13 josh.evans
josh.evans
  • 1,439 posts
Posted 14 May 2010 - 09:03 PM
i would be interested if you could some how make it so it attaches to a rear roll cage?
well done though looks fab
josh
#14 josh.evans
josh.evans
  • 1,439 posts
Posted 14 May 2010 - 09:06 PM
and what sort of delivery price we looking at too?
#15 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 14 May 2010 - 09:07 PM
Jon, I hate to pick fault but that single eyebolt worries me, I'd seriously consider reinforcing that.
Also(tmf gestapo head on!!)
To offer services to TMF members you need to register as a trader, PM jordie for details.
