For anyone whos thinking of chopping the front off their cluby and having a removable/flip on there, then read this.
I decided to put my brace bars on tonight, but the inner wing section were they bolt on at the top is different to the round nose wing (even tho the brace bars are 'universal'). There is a bulge right were the bars need to go. I mulled it over for a while and came up with 2 options - Cut the bulge out and weld a plate in its place, or cut the bars a few inches from the end and bolt the ends on at a better angle and wld the rest of the bar to it.
I went for the second option and it worked out well, I'll post some pics soon.
The inner wing of the cluby has a different angle on it too, so I think even with cutting the bulge out there would be issuse with getting the bars to bolt up snug. Has anyone else with a cluby come across this problem too?
Brace bars
Bluemini
, Apr 06 2004 08:58 PM
4 replies to this topic
Posted 06 April 2004 - 08:58 PM
Posted 06 April 2004 - 10:05 PM
my mate found this, luckily he now has a round nose! and they dont mye the bars for the clubby. luckily the bars fitter stright onto mine!
the inner wing oin the round nose it sright where as ont he clubby it goes in doesnt it?
Posted 06 April 2004 - 10:11 PM
When i fitted a clubie front flip to my round nose , I made my own brace bars from inch square box section ( i was lazy and welded them to the inner wing at one end and the subframe at the other ) solid mounting did the trick but the welds cracked because i left the other mountings as rubber , lesson learned !
Posted 07 April 2004 - 06:48 PM
yeh i had to solid mount mine aswell, made it alot louder but more responsi ve so im happy with it
Posted 07 April 2004 - 08:08 PM
Mine's already solid mounted, I kinda do that as standard on all my minis so they handle better, and put poly bushes every were else...
