crankshaft dampers
Posted 14 November 2005 - 06:01 PM
My question is,
What do the high performance ones offer and are they necessary for my rebuild?
Posted 14 November 2005 - 07:27 PM
He found that the crank tails on the 1300s would crack or break up completely at long periods above 8500rpm because they twist when accelerating. I know you wont be taking your engine to these hights but the whole point of having a crank damper is for reliability so this science still applies just on a smaller scale. Check his website for some pretty 5h1t hot products.
http://homepage.ntlw.....20wheel 2.jpg
www.lynxae.com
Posted 14 November 2005 - 07:31 PM
The ultimate in crankshaft damper is the viscous type, but could set you back 200 notes
Posted 14 November 2005 - 07:40 PM
MiniSprocket is right though. A brand new damper is really what you want.
Posted 14 November 2005 - 07:52 PM
You are aware that these are tuned for the engine they are on. Also they are not solely filled with fluid, there is a steel ring that floats in this fluid and the toleremces to which these parts work together is very close.When I get my milling machine and lathe, Im gunna try and make my own. Im going to make parts of it hollow so I can fill it with fluid so it will be perfectly balanced at high rpm.
http://www.fluidampr.../howitworks.htm
Posted 14 November 2005 - 08:42 PM
Posted 14 November 2005 - 09:10 PM
The Mini Cooper S two piece one is the best according to very many rce engine builders who have tried many different types. The friction clutch type one even seems to give problems in Mini's when they are the best available for many other engines.
It's not got anything to do with the flywheel mass AFAIK. As far as I'm aware it's balancing the flex caused by the cylinders firing. The crank spinning at high RPM without the fuel and ignition running (being driven by a balancer for example) won't really flex or twist at all.
The genuine Cooper S item is still available new from Minispares and costs about £40.00 more than the final price of the second hand one on E-bay. If you get this do get the locktab for the screws that hold the two together.
Edited by Dan, 14 November 2005 - 09:16 PM.
Posted 14 November 2005 - 11:21 PM
[Edit]
My mistake, i found reading that statement a little difficult and i miss understood. sorry for the confusion.
That is for the damper only, you still have to buy the pulley which is about another 40 notes.
[ Edit]
Torsional vibration is as Dan said generated by the firing of the cylinders generating bending loads. This causes the crank to flex and if left un checked will cause localised work hardening of the metal and then failure. This is more of a problem in the A series engine because its only a three bearing crank. The damper changes the frequency of the vibration resulting in a more satisfactory fatigue life.
Leave one off a heavily modified high reving 1275 will lead to the crank breaking
Edited by Mini Sprocket, 14 November 2005 - 11:27 PM.
Posted 16 November 2005 - 06:22 PM
I am not going to be absolutely revving the nuts off the engine, or really racing it all the time. It will be a weekender and the odd track-day. So I guess a new crank pulley (a standard one) will suffice.
Once again, cheers for the advice peeps! :wink:
Posted 16 November 2005 - 07:07 PM
Posted 16 November 2005 - 07:09 PM
But the coinage won't allow at the moment! :sad:
Posted 16 November 2005 - 07:12 PM
Ben after the TPI set up my self to go with my high tec 16valverIt would, of course, be nice to go to a cooper s style damper and a poly vee belt set up.
Posted 16 November 2005 - 08:44 PM
Sadly there isn't a poly-vee crank pulley which will accept the Cooper S damper ring at the moment AFAIK, if there was I'd already have it!
