These are from my rear brakes. I know it isn't the greatest picture but anyone have an opinion if these look too worn or okay to put back on? I think the remaining surface is about 2mm or so and about twice as thick as the underlying metal.
Brake Shoes Worn?
radgator1
, May 05 2010 09:07 PM
3 replies to this topic
Posted 05 May 2010 - 09:07 PM
Posted 05 May 2010 - 09:09 PM
Id be putting those back in, but i dont do many miles and I regularly service/strip/check my minis over.
Posted 05 May 2010 - 09:14 PM
I'd re-use them. As long as your not down to the metal and are still able to get them adjusted they should be fine.
Posted 05 May 2010 - 09:19 PM
Thanks for the quick replies. Looks like they are going back in. That's good, save the cash for other bits I need. Is it okay to clean them up a bit with the spray brake cleaner in the can? I'll try to keep it off the braking surface of course.
