Coil Wire Size
Posted 05 May 2010 - 12:54 PM
Posted 05 May 2010 - 01:01 PM
Posted 05 May 2010 - 01:44 PM
I need to replace the white and pink wire running from my coil to the fuse box, what size wire do i require? the car is a 1990 998cc with aftermarket electronic ignition, thanks
Posted 05 May 2010 - 03:19 PM
Posted 05 May 2010 - 03:47 PM
Posted 05 May 2010 - 04:26 PM
Posted 05 May 2010 - 06:17 PM
voltage at coil feed with ignition on is 12v, and actually having just looking the coil does say 12v
Edited by smj, 05 May 2010 - 06:28 PM.
Posted 05 May 2010 - 10:18 PM
Posted 06 May 2010 - 12:23 AM
If it isn't ballasted just crack on with a bit of wire 1mm sq.
