Fixing of front registration plates: vehicles registered on or after the relevant date
6.—(1) This regulation applies to vehicles, other than works trucks, road rollers and
agricultural machines, first registered on or after the relevant date.
(2) Except as provided in paragraph (5), a registration plate must be fixed on the front of the
vehicle in the manner required by paragraph (3).
(3) This paragraph requires the plate to be fixed—
(a) vertically or, where that is not reasonably practicable, in a position as close to the
vertical as is reasonably practicable,
(b) in such a position that in normal daylight the characters of the registration mark are
easily distinguishable from every part of a relevant area having the diagonal length
specified in paragraph (4).
(4) The diagonal length of the relevant area is—
(a) in the case of a mark having characters the width of which is at least 57 millimetres,
22 metres,
(b) in the case of a mark having characters the width of which is 50 millimetres, 21.5
metres,
© in the case of a mark having characters the width of which is 44 millimetres, 18 metres.
(a) OJ No. L75, 6.4.70, p. 25.
(b) OJ No. L262, 27.9.76, p. 85.
© OJ No. L171, 30.6.97, p. 49.
5
(5) In the case of a motor cycle or a motor tricycle which does not have a body of a type
which is characteristic of the body of a four-wheeled vehicle—
(a) a registration plate must not be fixed on the front of a vehicle if it was first registered
on or after 1st September 2001,
(b) a plate need not be fixed on the front of the vehicle if it was first registered before 1st
September 2001.
Just because others have stick on number plates does not make it legal!
