Bmw 16v K1200rs Head Conversion 1380cc Block
116 replies to this topic
#106 mini_nutz
mini_nutz
  • 117 posts
Posted 13 March 2013 - 09:08 PM
mini-nutz
Where did you get the ram tubes for the throttle bodies? And do they do them for the K1100 throttle bodies?
Steve
Hi Steve,
I got the ram tube with the conversion kit from Specialist Components Click here! Yes they do them for the K1100 and K1200 heads. I know this as I was sent the incorrect ones but they exchanged them. I cannot find them for sale on the website but may give them a shout!
BR
Warren
#107 OZMINI
OZMINI
  • 48 posts
Posted 15 March 2013 - 11:29 PM
Thanks Warren
I'll get on to John at SC and see what I can sort out.
Steve
#108 mini_nutz
mini_nutz
  • 117 posts
Posted 30 September 2013 - 08:14 PM
Hi Steve,
Sorry I have not replied to your email I have not been on TMF for some time. I thought I would put the 2.4mm valve lift cam timing guide that I used on the forum for others.
1. Set the cylinder no.1 to TDC using a DTI gauge.
2. Set the DTI gauge up on the inlet cam. Make sure that the pointer axis is parallel to the valve. (It is important to get an accurate measurement - DTI (Dial Test Indicator) gauges are precise measurement equipment that measure graduations in 0.001mm.
3. Ensure the DTI pointer is on the back of the cam bucket. (DTI needs to have a long thin pointer attachment or it will foul on the cam lobe and give an incorrect reading)
4. Rotate the Inlet camshaft clockwise using a 19mm spanner from its base circle until a lift of 2.4mm* has been achieved.
5. Repeat the same process for the Exhaust camshaft but this time rotate the Exhaust camshaft anti-clockwise.
*2.4mm is base set up for the 1200 range 16v RS cams and standard 8v cams. Note: For LT 16v cams 2.0mm should be used.
This information is a guide - use at your own risk!
Always be very careful when independently turning the crankshaft or camshafts to ensure that your valves do not come into contact with one another or the pistons. If you get any resistance stop and investigate!
Hope all are well :)
Warren
#109 acheyford
acheyford
    Starting My Mini Up
  • 1 posts
Posted 12 February 2014 - 10:22 PM
Hi warren
Excellent reading in this topic I'm half through my build of much same spec as yours good to read your build pro's & conns will help me adviod some problems with mine
Thanks james
#110 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 14 February 2014 - 12:01 PM
Thats amazing!
#111 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 15 February 2014 - 07:50 PM
Brilliant guide!
#112 mini_nutz
mini_nutz
  • 117 posts
Posted 22 March 2014 - 06:23 PM
Hi all,
Insurance renewal time - thought I would share the pics with you :)
Enjoy
Warren
#113 Jayme 1275
Jayme 1275
  • 488 posts
Posted 22 March 2014 - 07:24 PM
Hows this going for you mate? would you do anything different if you where building the engine again.
#114 mini_nutz
mini_nutz
  • 117 posts
Posted 13 September 2014 - 08:09 PM
Hi all,
I have finally decided that to sell up and move onto other projects.
If anyone is interested I have put her up for sale on ebay
http://www.ebay.co.u...E:L:LCA:GB:1123
Kind regards
Warren
#115 kiwiinwgtn
kiwiinwgtn
    Starting My Mini Up
  • 2 posts
  • Local Club: MOWOG
Posted 12 March 2020 - 11:57 PM
Hi all
I am using the K1200LT head and was wondering does the hole circled in read need to be pluged
It appears to go through to the oil gallery
It only appears on the 1200 head
Bernard
#116 DeadSquare
DeadSquare
  • 3,101 posts
Posted 13 March 2020 - 07:51 AM
Surely, the whole face is going to be covered by the sheet of aluminium with cam oil seals etc, so look and see if there is a corresponding hole that lines up.
#117 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 03 April 2020 - 10:37 PM
Hi all
Bernard
Just noticed this, yes I would plug it, your right it's on the main oil gallery, you could loose oil pressure to your cam bearing if not plugged.
