Bmw 16v K1200rs Head Conversion 1380cc Block
116 replies to this topic
#46 Jayme 1275
Jayme 1275
  • 488 posts
Posted 06 March 2011 - 09:22 PM
Looking good. Not a wile pile of clerance between manifold and bulkhead. Will that be an issue?
#47 mini_nutz
mini_nutz
  • 117 posts
Posted 19 March 2011 - 08:46 PM
Hi everyone,
A quick update of the progress so far.
Last week I completely stripped out my engine bay inc all ancillaries, as I had a small brake fluid leak last year from one of my master cylinders which destroyed the paint work. I managed to get my hand on some master cylinder extenders to prevent another leak. Once the engine was out I wanted to re-use some newish parts off my old 1400cc lump to fit onto my new engine. Prior to fitting the parts I had to clean and blast them, all brackets have been primed, painted black and lacquered. Unfortunalty I don’t have access to a painting oven therefore I have to wait for good weather. As the weather was perfect today my mate Alex painted the engine bay for me.
The old 1.4 lump ready to be removed.
Attached File  DSCN0276_640x480.jpg   58.01K   87 downloads
Close up on damaged paint area.
Attached File  DSCN0278_640x480.jpg   39.91K   98 downloads
Me prepping the engine bay for etch primer.
Attached File  DSCN0290_640x480.jpg   43.83K   145 downloads
Engine bay re-painted and lacquered ready for engine.
Attached File  DSCN0317_640x480.jpg   49.45K   117 downloads
I have spent the week putting the final touches onto the engine; I fitted the clutch housing cover from the old engine with a new clutch arm and clutch release bearing. I have also fitted new engine mounts. I came across a minor problem as I there was not enough room to fit the cam belt tensioner. I had a 5mm spacer made that would fit between the damper and the crank driving wheel. This increased the gap between the engine side plate and the crank damper and gave me 3mm clearance gap. I decided to scrap the idea of using the v belt crank damper and instead I’m using the up rated belt system that I had on my old engine. As the up rated belt is wider than the 'v' belt I need to fit a bigger spacer under the crank position sensor arm to ensure it aligns with the crank position wheels correctly. All pipe work has been temporally fitted to ensure I’m ready to start installation tomorrow.
Pics of the completed engine.
Attached File  DSC_0002_640x425.jpg   43.12K   226 downloads
Attached File  DSC_0003_319x480.jpg   39.79K   168 downloads
Attached File  DSC_0007_319x480.jpg   39.71K   265 downloads
Attached File  DSC_0012_319x480.jpg   43.2K   304 downloads
Tomorrow I will install the engine and start installing all the components and accessories inc the ECU.
Check back soon for more progress.
Warren
#48 mini_nutz
mini_nutz
  • 117 posts
Posted 19 March 2011 - 09:17 PM
Forgot to add a pic of the back of the engine.
Attached File  DSC_0004_640x425.jpg   47.56K   303 downloads
#49 mini_nutz
mini_nutz
  • 117 posts
Posted 20 March 2011 - 06:53 PM
Well here you go. Its in. :)
Attached File  DSC_0014_640x425.jpg   57.14K   322 downloads
Attached File  DSC_0015_319x480.jpg   43.23K   267 downloads
Attached File  DSC_0016_319x480.jpg   40.36K   221 downloads
Attached File  DSC_0018_319x480.jpg   42.16K   241 downloads
Attached File  DSC_0017_319x480.jpg   38.33K   190 downloads
Warren
#50 andymini12
andymini12
  • 812 posts
Posted 20 March 2011 - 07:23 PM
That looks great.
#51 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 22 March 2011 - 05:38 PM
wow that looks sweet :P
quite tempting to do :P
#52 george91
george91
  • 883 posts
Posted 31 March 2011 - 09:51 PM
Very nice, will be a suprise for people when you open the bonnet and they see that. What ECU are you using?
EDIT: just been reading, your using the SC ecu.
Edited by george91, 31 March 2011 - 09:55 PM.
#53 mini_nutz
mini_nutz
  • 117 posts
Posted 29 April 2011 - 05:39 PM
Hi all,
Just a quick update on progress.
Things have been going well just a little slow. I have now plumbed in 95% of the engine, all that is left is the hoses either end of the copper fuel pipe. Had some troubles trying to get the lower radiator hose to fit without fouling on the cam belt. Below is a pic of the final solution.
I have installed two new 8mm copper fuel (feed and return) lines under the car, this job was akward. I should have installed them prior to installing the engine as it would have been easier with both the front sub frame and rear beam axel removed. Anyhow only removed the beam axel in the end. The mpi fuel tank has also been fitted.
Still need to fit the radiator but currently working on that one.
The original bonnet fails to close. doh! I dont want to prop the front or rear up so managed to get KAD twin cam fiberglass bonnet, that needs some small work as someone cut the front lip off. I dont want any external fixings so i have cut up an old steel bonnet for the fixings, I just need to bond them onto the fibreglass now. I hope Sikaflex and some additional fiberglassing should do the trick. :-s
All the wiring has now been completed and tested. The engine turns over with excellent oil pressure on the starter motor.
I have also made the oil filler point to go onto the clutch housing. Just to paint and fit it.
Enjoy the pictures.
Attached File  DSC_0078_640x425.jpg   36.63K   111 downloads
Attached File  DSC_0080_640x425.jpg   40.06K   119 downloads
Attached File  DSC_0079_640x425.jpg   52.56K   233 downloads
Attached File  DSC_0083_640x425.jpg   28.33K   107 downloads
Attached File  DSC_0084_640x425.jpg   34.45K   77 downloads
Attached File  DSC_0085_640x425.jpg   22.91K   41 downloads
Warren
#54 Artstu
Artstu
  • 830 posts
Posted 29 April 2011 - 05:52 PM
Simply stunning, that BMW head looks right at home in a Mini
#55 mini_nutz
mini_nutz
  • 117 posts
Posted 18 May 2011 - 07:10 AM
Hi all,
Its Alive!! :techsupport:
Needs setting up but it runs.
Have a look at the video K1380rs.
Warren
Edited by mini_nutz, 18 May 2011 - 07:46 PM.
#56 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 18 May 2011 - 08:42 AM
Hi
Glad alls going well,
that exhaust downpipe is mini porn, I might get one for my bedroom.
Looking at the photos is the fan on the right way?
Happy motoring sound and looks really nice.
Good job
John
#57 mini_nutz
mini_nutz
  • 117 posts
Posted 18 May 2011 - 09:10 AM
Hi
Good job
John
Hi John,
Well spotted! When I first built the engine I had clearance issues with the fan blades and the crank trigger wheel as i was missing the all important fan spacer. I have now fitted a fan spacer and put the fan on the correct way round. :techsupport:
Warren
#58 Jayme 1275
Jayme 1275
  • 488 posts
Posted 18 May 2011 - 01:20 PM
That looks at home in the engine bay indeed. Items it your going to spray the bonnet the same as they car
#59 mini_nutz
mini_nutz
  • 117 posts
Posted 18 May 2011 - 05:04 PM
Sorry about the video going pixelated at the end will upload another video later.
Warren
#60 mini_nutz
mini_nutz
  • 117 posts
Posted 18 May 2011 - 05:08 PM
Bonnet will be carbon wrapped once all modifications have been completed. If i decide at a later date I dont like the carbon look it can always be painted to match the car.
Warren
