Tappy Noise Under Load
Posted 27 April 2010 - 07:15 AM
Year: 1997
Hi guys
i am running an Mpi engine with 1.5.1 roller tip rockers. I am getting this unnormal tappy sound when the car is under load. As soon as you start to accelerate you get this tappy noise.
I have checked and rechecked the rocker gap, set to .17 thou. left them for a week then rechecked. But still the noise persists.
There is oil in the car, andwhen teh car is idling you can see the oil in the rocker cover. The noise is not present when the car is idling.
I know 1.5.1 rockers are unusally loud when running. But this noise only apears when under load.
Mike
Posted 27 April 2010 - 07:21 AM
Sam, what you say is right but if it only happens under load it suggests something on the crank or in the drive train. How closely related to the engine speed is it? It ought to get noticeably worse as the engine warms up if it is something like a big end that rides on a film of oil.
Posted 27 April 2010 - 07:22 AM
Posted 27 April 2010 - 07:32 AM
The engine was only rebuilt a year ago, and has covered 7000 miles since the rebuild. Could the big ends go in that space of time.
The noise sometimes gets worse or quitens down when I go around a corner.
My oil pressure gauge is bust, i am in need of a new one
Mike
Posted 27 April 2010 - 07:36 AM
Posted 27 April 2010 - 07:42 AM
Posted 27 April 2010 - 07:43 AM
If it is the big ends woudl there be any other indications?
And will it affect it if I continue to drive it? Well apart from trashing my crank
Mike
Posted 27 April 2010 - 07:47 AM
Posted 27 April 2010 - 10:52 AM
7k makes a big end unlikely, enough to show up any build or running issues, but not enough for wear. Not impossible though. cornering might cause oil starvation or it might just exert enough force to make something catch. Try changing gear to see if it's defo engine speed related.
When you say changing gear? you mean like normal driving lol
I have not heard the noise when reversing the car if that helps
Also I have noticed that the oil dip stick is not showing a oil fluid level.
However I know there is oil in the car. When I changed the oil the other day, I stuck in 5 liters of 20/50 and it was still not showing a clear mark on the dip stick
Could this point to an issue?
When the engine was rebuilt there was a center oil pickup fitted.
Mike
Posted 27 April 2010 - 11:58 AM
Posted 27 April 2010 - 03:00 PM
Would this indicate to big ends? is there any other signs that would point to big ends before I go ripping the engine apart
Mike
Posted 27 April 2010 - 03:05 PM
Posted 27 April 2010 - 03:23 PM
It ould be slight 'pinking' under load due to the igniton timing being slightly too far advanced. Check the timing.
car is an MPi and the timing can't be altered
Mike
Posted 28 April 2010 - 07:03 AM
ran the car for a bit then checked the oil levels. I am now getting a decent level.
Still having the tappy noise when driving thou, not impressed
So going buy folks responces it sounds like the big ends
Is this a nightmare of a job?
Mike
Posted 28 April 2010 - 12:33 PM
How come the tapping noise only apears when the car is in gear and driving. The noise does not apear when the car is idlling, or when the car is in gear and only a little throttle is applied.
Or when the car is being revved from idle?
totally confussed
Mike
