im having a lot of trouble with fitting the glass back into my doors. iv bought new runners and the rubber inserts but cant seem to fit it all together.
whats the best way to do it? do you puth the runners on the glass first then try and fit it in the door?
please help
cheers sean
Door Glass Fitting
sheepy89
, Apr 26 2010 09:57 PM
8 replies to this topic
Posted 26 April 2010 - 09:57 PM
Posted 26 April 2010 - 10:55 PM
bump
Posted 26 April 2010 - 11:05 PM
you should be able to manage with the runners on it you remove the waist seals (that's the trim along the bottom of the opening). Where does it get stuck, do you get the glass back in side the frame?
Posted 26 April 2010 - 11:46 PM
i did this today, u need a haynes manual.
i will warn ya now, i am crap at explaining and will not always use technical words, sorry lol
it might be best is there is 2 of you, 1 to hold the glass and 1 to put the runners on the rails
u want the rails atatch to the window first. then you need to unscrew the window windey bit in the centre, they were rather stiff for me, then slide the window in (take off the seal bits first).
you want to atatch the runners onto the rails in the big hole where you took the winder out, starting with the rail closest to the car (it will be obvious why), once they are on gently move the window down with the winder mechanism, and screw back into place. then just re-atatch all the fixings
Posted 27 April 2010 - 06:19 AM
i just followed the haynes when i did mine
it's all in there step by step
Posted 27 April 2010 - 11:36 AM
Here's the picture from the Haynes manual:
This should help.
This should help.
Posted 27 April 2010 - 05:11 PM
cheers ill have another bash tonight and let you know how it goes.
sean
sean
Posted 27 April 2010 - 05:18 PM
I found it easiest to fit the rubber to the glass then the runner over the rubber. Surprising how well those runners hold on when new!
Posted 02 May 2010 - 01:52 PM
managed to get it done the other day. ended up sealing the rubbers onto the glass then following the haynes restoration manual and bobs your uncle it worked.
cheers for all your help.
sean
sean
