Bmw Mini - How To Seperate Handbrake Cable From Caliper?
18 replies to this topic
#16 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 26 April 2010 - 08:38 PM
The groove is there to hold the protective rubber boot on when you pull it all together, it is not a seat for a circlip, although it does look that way in my pictures!
Yep - looks like it should just pull out but it is stuck so fast with no movement I feel there must be something I am missing! If I hit it any harder I will damage it....
Thanks for the help so far.
It will come out with work, if it is really so stuck that damage to the cable is likely, then a junior hacksaw cut into the caliper to the cable (take care when near the cable itself) will help free it off, take a look at the new caliper you will see that how the cable sits into the hole.
#17 MRA
MRA
  • 7,607 posts
Posted 26 April 2010 - 08:53 PM
And I am guessing that the OP has had to pay a surcharge on the calliper, which will be lost if the calliper is damaged :(
Penetrating oil and keep on spraying each day for a week.
#18 cambiker71
cambiker71
  • 1,050 posts
Posted 26 April 2010 - 10:13 PM
If that's the case then this or new cables too
#19 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 01 May 2010 - 09:59 AM
I'd take a look at your new calliper, it might shine some new light on how the cable is held in place and from which side :mrcool:.
