Fitting Gmax Shocks
6 replies to this topic
#1 bathman06
bathman06
  • 22 posts
Posted 24 April 2010 - 12:12 PM
Model: City
Year: 1982
Description of problem
Ive just bought some new Gmax shock absorbers to replace the standard worn out ones, but when coming to fit them on the front the Gmax are smaller and dont fit, i thought the Gmax ones would replace the standard ones without the car being lowered or is this not the case?
Attached File  DSC_8528.JPG   2.25MB   29 downloadsAttached File  DSC_8526.JPG   2.87MB   32 downloads
Any non-standard parts that might be involved with the problem?
#2 miniJJ
miniJJ
  • 262 posts
Posted 24 April 2010 - 12:16 PM
If I remember correctly Gmax are lowered by 20mm. So they won't fit on standard suspension unless the cones in poor nick? If you want to fit them you could get some HiLos.
JJ
#3 bamby
bamby
  • 1,342 posts
  • Local Club: Fylde Mini Club
When I fitted my replacement dampers on mini - i found that i needed to support the disc assambly on a jack to get the bolt through the lower part of the schoker. i put this down to the new dampers having more resistance in them than the old ones
#4 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 24 April 2010 - 12:22 PM
they are the same shocks that i have, they are for lowered minis, being abit shorter so not to bottom out like a standard height shock would do on a lowered mini!
#5 bathman06
bathman06
  • 22 posts
Posted 24 April 2010 - 12:25 PM
Thanks, so if jacked up the hub would the Gmax's work ok or would i need the HiLos?
#6 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 24 April 2010 - 12:29 PM
you would prob end up wreckin them lol they wont give the right ammount of travel downwards so will bang and crash about, when on the rebound from pot holes etc, best to fit your old ones back on the front for now, and get some hi-lows fitted and lower your mini slightly at the front for maximum effect
#7 bathman06
bathman06
  • 22 posts
Posted 24 April 2010 - 12:35 PM
Ok thanks for the advice, looks like il be ordering some Hi-Lows then!
