? Power Commander For 5pw R1 Engine
6 replies to this topic
#1 johon6
johon6
  • 20 posts
Posted 22 April 2010 - 07:31 PM
hi all, am i looking at the right thing
power commander £ 250 ish quid is that the right thing im looking at ? clueless to be perfectly honest
told to get one as im putting a 5pw in the pup
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 22 April 2010 - 10:53 PM
Remind me, is 5PW injection? I know 4XV and 5JJ are carbs
Edited by R1minimagic, 22 April 2010 - 10:54 PM.
#3 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 22 April 2010 - 11:08 PM
5pw is injection, the dynojet commander is a valuable addition but is not needed immediately, you can add it later very easily. It's a unit that allows to adjust fuelling by over-riding the settings on the factory ecu.
It's a plug and play unit with 2 simple connections that atatch to the yamaha part of the loom you will be adding to the mini
Look for a second hand unit, don't buy new, and the optional additional small LCD screen is a very useful extra as it allows you to see what is going on without having to connect your laptop
#4 R1minimagic
R1minimagic
  • 4,660 posts
Posted 23 April 2010 - 06:33 AM
They are on ebay all the time.
#5 johon6
johon6
  • 20 posts
Posted 26 April 2010 - 07:32 PM
im just wondering whether its worth getting now save mithering later, as the promo boys might aswell plug it in for me when i deliver the pup.
cheers guys, as long as i know im looking at the right thing,
its the 5pw engine ive got by the way
the next 5 weeks just can go quick enough
#6 johon6
johon6
  • 20 posts
Posted 26 April 2010 - 07:38 PM
its injection the 5pw mate
jb
#7 1989mini1293
1989mini1293
  • 28 posts
  • Local Club: North somerset Mini Club
Posted 28 April 2010 - 08:13 PM
It is definatley worth getting a power commander.
As it will need a new fuel map because you'll end up using a different exhaust and air filter to standard when fitting to the car (Different air flows and exhaust back pressures afffect air / fuel mix required).
Going to a dyno is the best thing to do.
But dependign on where you live depends on where and if there is a facility any wher near you able to do a bike engine car.
The other uption is to fit a Dynojet Wideband commander(not wideband commander 2) as well.
ok this costs abit more than a dyno secion might but you get a real time Air / fuel ratio meter for the dash
+ it can data log for 10min and record rpm throttle position and mixture via wideband lamda sensor in exhaust.
This give you all the info need to adjust the fuel map in the right areas.
bonus is you can make up the map yourself from the data logged.
so the real life road we drive on becomes your rolling road.
I have fitted it to mine and am in the process of making up my own map.
Mini 1293
Edited by 1989mini1293, 28 April 2010 - 08:14 PM.
