2.0 8v C20ne
57 replies to this topic
#16 topcat
topcat
  • 276 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 13 June 2010 - 07:28 PM
Took the engine/subframe out on saturday. Got the mini back in the garden!
#17 B18c Mini
B18c Mini
  • 32 posts
Posted 07 July 2010 - 07:58 PM
Any more work done on the car???
I got some more of the boot floor/arch cut away..
Will try and get a thread going soon! (I'm lazy)
I had a bit of a hangover after the afternoon of beer!
#18 terryg
terryg
  • 63 posts
  • Local Club: somerset rusteez
Posted 07 July 2010 - 08:26 PM
nice one mate. last time i saw that engine it was behind me at castle combe lol
#19 topcat
topcat
  • 276 posts
Posted 28 July 2010 - 09:29 PM
Just starting to get a bit more time to spend on the conversion now. Got the engine cleaned up and painted. Need to get a new clutch. Got a new F20WR gearbox. Also got a MPi Fuel tank and pump and fuel lines.
The new F20WR gearbox has a hydraulic clutch which I am thinking of using. Does anyone know if the standard mini clutch master cylinder will work?
#20 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 28 July 2010 - 10:11 PM
Yup it should do, popular conversion changing the gearboxes from cable clutch to hydraulic clutch when putting in mini :thumbsup:
Edited by GreaseMonkey, 28 July 2010 - 10:11 PM.
#21 topcat
topcat
  • 276 posts
Posted 02 August 2010 - 10:07 PM
No going back now, chopped the front end of tonight:
#22 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 04 August 2010 - 09:33 PM
Bet there where a few moments of doubt before you made the 1st cut!
Making good progress there chap and a MPI tank/lines is def an easier solution that the way I did it. And I'm sure the mini master is what the XE boys use :D
#23 topcat
topcat
  • 276 posts
Posted 13 August 2010 - 08:20 PM
New Clutch Fitted:
New F18WR gearbox fitted:
#24 topcat
topcat
  • 276 posts
Posted 16 September 2010 - 07:28 PM
Finally got round to re-doing some of the welding on the frame and cleaning it up:
I then decided to re-make 2 of the engine mounts. I didn't like the way you could only hand tighten the rubber mounts to a nut inside the box section. I have now bolted the rubber mount to a plate which can be bolted to nuts welded into the frame:
I still need to strengthen this one with some gussets:
Engine in the frame:
I hope I don't have to take the engine out the frame now because it's pretty heavy. It's going to be tricky getting it through my living room door though!
#25 topcat
topcat
  • 276 posts
Posted 16 September 2010 - 08:18 PM
Oh forgot to add, got my front end! Thanks ABS Motorsport, looks good!
#26 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 16 September 2010 - 09:10 PM
Are those engine mounts flat to the sub frame? You are better angling them in. That way any movement of the engine and gearbox back and forth puts the mounts into (some) compression which they are designed for not shear. If you have a look at an all speed frame their mounts are angled in.
Good luck with the project
#27 daveeeeee
daveeeeee
  • 684 posts
Posted 16 September 2010 - 09:40 PM
I second that, but it's a chance to do some more of that tidy welding :D
#28 topcat
topcat
  • 276 posts
Posted 17 September 2010 - 07:44 AM
Yer they are flat, in hind sight they would be better angled in, however they previous owner had them flat and the engine didn't really move much and the old rubber mounts didn't show any signs of degradation so I guess it's ok. The allspeed kit uses softer rubbers I think, these are land rover V8 mounts which are quite stiff. Yer I was quite pleased with that weld on the gearbox mount! It's so much easier welding thick steel!
#29 M J W J
M J W J
  • 976 posts
Posted 17 September 2010 - 12:48 PM
The conversion kit is out of pootle right? From what I read of that build, pootle wasn't driven that much with the engine in. I would imagine that 20000 miles later it may be a different matter. I would personally change them now as you have the chance. It is the joint between the metal stud and the rubber that will most likely break first.
#30 topcat
topcat
  • 276 posts
Posted 20 September 2010 - 11:48 AM
Well I can't honestly see it making any difference, plus I doubt I will be doing 20000 miles with that engine, will probably have changed again to honda or something. Plus It's not exactly difficult or expensive to change a rubber mount if necessary.
