9975 replies to this topic
#9646 Quinlan minor
Quinlan minor
  • 1,385 posts
Posted 24 December 2024 - 09:47 AM
Thoughts on the red dots?
I have 'new' barely used (12,000 km - but 24 year old rubber cones...
I believe most would recommend replacing due to age, yes?
Four to six times, in twenty-four years, yes.
#9647 GT Jimmy
GT Jimmy
  • 1,674 posts
  • Local Club: S.U.N.M.C
Posted 30 December 2024 - 03:41 PM
I fitted my fuel filter, only took me 3 months after taking the old leaky one off. Need to up my game
#9648 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 30 December 2024 - 04:12 PM
Took the Mini out for a good run, only to discover that I have an exhaust leak from a crack in the manifold, a new one has been ordered from Minispares.
So my 1st task in the new year will be to replace the manifold, also going to replace all the engine steady bushes
#9649 Shooter63
Shooter63
  • 1,293 posts
Posted 31 December 2024 - 05:13 PM
Started making some sump plug adapters, I couldn't find my countersink tool, while looking for it I dropped a parting tool blade, which pierced an aerosol of grey primer, said primer went all over me, shut the workshop down, as evidently it wasn't my day.
Shooter
#9650 Cooperman
  • 23,569 posts
Posted 12 January 2025 - 05:42 PM
Yesterday my Grandson & I fitted a new navigator's seat to the '64 'S' historic rally car. It's a Cobra and the width at the shoulder level was a bit wider than the old one, so I had to move the mounts inboard by around 2 cm.
Then we changed all the old brake fluid for new AP600 comp fluid.
This week I have to fit the wheels. lower the car and start the engine. Then set the ride height with the new ones an Hi-Lo's.
New heated screen will then be fitted and Osram Night-Breaker bulbs in the Hella Headlights.
Just the grill and spot-lamps to be fitted and it'll be rally-ready again.
#9651 Midas Mk1
Midas Mk1
  • 5,853 posts
Posted 12 January 2025 - 06:39 PM
Wirral to Llandudno in convoy with Dad in the Midas, top day out.
#9652 lsto
lsto
  • 723 posts
Posted 01 February 2025 - 06:06 PM
Replaced my perished and split rubber exhaust mounts with poly bush ones. Hopefully they will last longer than the year the rubber ones did.
#9653 Podman
Podman
  • 218 posts
  • Local Club: -
Posted 14 February 2025 - 10:00 AM
Fitted a pair of fog lights to the front, swapped out the hydraulic brake light switch and fitted a high level brake light to the parcel shelf.
#9654 Mito
Mito
  • 460 posts
Posted 23 February 2025 - 10:52 AM
Fitted new front number plate.
I've bought a set of pressed plates. Next up, flat and polish the boot and fit the rear :)
#9655 Steve220
Steve220
  • 5,144 posts
  • Local Club: BMC
Posted 23 February 2025 - 11:08 AM
MOT complete and did some mapping! Cold weather means its hitting boost cut 😆 Also made a list of things to do pre show season!
#9656 petey81
petey81
  • 1,354 posts
Posted 24 February 2025 - 11:31 AM
Just put it in for an MOT and passed. Only mention was for a top arm seal which was only replaced late 2023! Quality of some rubbers are shocking
#9657 Cooperman
  • 23,569 posts
Posted 24 February 2025 - 03:24 PM
Nothing on either Mini, but timed in the cam on a 1972 Midget 1293 engine which I am building for a friend. Next job is to fit the rear oil seal modification and the flywheel/clutch.
I have used the new Mini Spares Evolution pistons instead of the 21253's. They look to be a fantastic quality and design, especially for the price. I've also fitted the MS Evo001 cam, so it will be interesting to see how it goes with its larger inlet valves and gas flowed head at 10.2:1 CR.
#9658 Landie
Landie
  • 58 posts
  • Local Club: Me
Posted 28 February 2025 - 02:04 AM
Put new plates on, changed oil and filter, fitted subwoofer and drove around getting lots of questions asked about it. The best thing was I had FUN
#9659 cooperd70
cooperd70
  • 793 posts
Posted 28 February 2025 - 07:06 AM
Took the car out for the day in the 🌞 and ended up at Gilks' Garage Cafe in Kineton for a spot of lunch
#9660 roblightbody
roblightbody
  • 460 posts
Posted 01 March 2025 - 03:22 PM
Getting it ready for its MOT and service on Monday, with a wee to-do list for my brilliant mechanic.  Feeling positive, compared to this time last year, when it wasn't running at all.
Fixed the droopy door mirror, fixed the interior light switch, some wee bits of touch up paint here and there, tested the bulbs, wipers etc, and as long as it doesn't start to rain, I'm about to try to get some shine back into the completely flat paint (again).
    Bing (2)
