9724 replies to this topic
#946 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 09 April 2011 - 11:26 PM
fitted the new steering rack and removed all the wheels ready for new yokos
#947 bruders 338
bruders 338
  • 174 posts
Posted 10 April 2011 - 08:25 AM
MiniAlex did you put any copper grease on the BACK of the pad where the piston push's against the pads... this helps
Edited by bruders 338, 10 April 2011 - 08:26 AM.
#948 Duncy H
Duncy H
  • 388 posts
Posted 10 April 2011 - 09:39 AM
Fitted new break pads, but now the front breaks are squeeling?
Standard break discs, but with Mintex pads.... why does it squeek when I break :) ? It never did it before.....
As said before grease on the back of the pads helps prevent squeaking. It could just be that the pads need to be left to bed in. When they are first fitted it is likely that the pads are not set up perfectly squarley to the disc. If a small fraction of the pad touches first it will cause vibrations and therefore noise. Once they have worn square they should be fine (Y)
#949 bruders 338
bruders 338
  • 174 posts
Posted 10 April 2011 - 10:09 AM
nothing exciting just replaced aux belt
also starting prep for spray job at end of the month
#950 imaparana
imaparana
  • 580 posts
Posted 10 April 2011 - 10:40 AM
Fitted new flip front and bonded on a new roof skin :)
#951 mattsminiresto
mattsminiresto
  • 46 posts
Posted 10 April 2011 - 08:01 PM
Drove it, in the super shiny currant bun ! MINT, just what mini's are owned for.
#952 samsfern
samsfern
  • 5,243 posts
Posted 10 April 2011 - 08:26 PM
sealed the exhaust and drove it, what was suppose to be a half hour dash around the back lanes in the morning, ended up being a day out for me and a friend, went to look in a garage called sva imports that specialise in high performance jap imports, and we sat in a few of them, then drove up to a spot i know in dover, right up high, with a superb view of the docks and sea. sadly clobbered the exhust on the drive home, as went down some seriously bumpy lanes, so its now blowing again :techsupport:, other than that no problems, not even a misfire, im slowly swaying towards keeping the mini.
Edited by samsfern, 10 April 2011 - 08:33 PM.
#953 MiniAlex
MiniAlex
  • 734 posts
  • Local Club: Mini's N Oatcakes
Posted 11 April 2011 - 12:08 AM
Fitted new break pads, but now the front brakes are squeeling?
Standard break discs, but with Mintex pads.... why does it squeek when I break :techsupport: ? It never did it before.....
Thank you for the advice :genius:
I didn't put any copper grease on the back's of the pads, I've never heard of doing that before! It only squeels when I come to a stop, if I press the brakes hard it doesn't squeel, but if I gentle on the brakes, thats when it seems to make the noise.
I will take the pads out tomorrow and put a bit of cooper grease on the back of the pads, I hope it stops them squeeling! I had great succsess today and managed to fit my new rear break shoes (also got mintex) now my handbreak is much better and the brakes in generall seem to be really good :(
Thanks again. Will let you know if it works!
Alex
#954 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 11 April 2011 - 06:24 AM
Spent 7 hours giving the car a detail ready to go up for sale.
#955 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 11 April 2011 - 08:08 AM
well my mg metro blew its gearbox . so i have sometihing to do now. apart from paint my mini put supercharged motor back together
#956 ccfc
ccfc
  • 62 posts
  • Local Club: Cardiff Minis
Posted 11 April 2011 - 12:07 PM
...Almost hit it with a sledgehammer after hours/days/weeks of trying to get the horn and flasher to work, buying a new fusebox and other parts. Today I almost resigned to taking it to a garage, then just before I gave up, rewired her for one last time....and she beeped and flashed.
It's like she knew I was on the brink of 'mini-hatred'. Had to give her a thank-you peck on the steering wheel. Swarfega time!
#957 backstreetclassics
backstreetclassics
    Previously known as minidan07
  • 1,898 posts
  • Local Club: essex mini club
Posted 11 April 2011 - 05:38 PM
today i fixed the speado change the rubbers on the lower engine steady adjusted all the engine steadys to try and stop the engine from moving stoped it a bit but still moves when under load
#958 Cooperman
  • 23,278 posts
Posted 11 April 2011 - 05:48 PM
Put my earplugs in and too the Cooper 'S' for its MoT.
Lovely to drive in the sunshine.
#959 davies145
davies145
  • 170 posts
Posted 11 April 2011 - 05:57 PM
went down a really bumpy country lane in my lowered mini wasnt the best idea going 2 mph and its ripping my exhaust off the whole time, now needing to fix it.
Ashley
#960 carts60
carts60
  • 1,007 posts
Posted 11 April 2011 - 07:39 PM
Got around to fitting my smoothy boot - only a year and a half after I bought it. Good things come to those who wait.
Most frustrating thing i'v ever done in my life though! All the holes were in the wrong place, its so thick that I couldnt put the nuts on the hinge threads. Its thickness also means it wont close unless you cut away half of the rubber seal.
Finished now though so its all good in the hood.
    Bing (1)
