#9451
Posted 07 April 2024 - 08:03 PM
Then I dropped the oil, only to find my chain type oil filter tool wasn't up to its job. Got a different one coming tomorrow, was tempted to go gorilla and whack a screwdriver through it
#9452
Posted 08 April 2024 - 06:03 AM
Replaced the petrol tank, due to rust inside it due to condensation.
I put a new tank in mine, so thought I'd try this to prevent it corroding again
https://bilthamber.c...roduct/gas-mac/
Only time will tell if it actually works
#9453
Posted 08 April 2024 - 11:32 AM
Started prepping the steel wheels for new tyres.
Wire wheel on grinder to bring it back to metal
Sanded and degreased
Etch and Primer applied.
#9454
Posted 08 April 2024 - 04:57 PM
Made 140bhp/154lbft at 10psi!! Started to get ignition break up last 5500rpm so replaced the MPi coil pack with a smart coilpack (internal ignitor) and it cleared! Also got cruise control working!!
#9455
Posted 08 April 2024 - 05:23 PM
Shooter
#9456
Posted 10 April 2024 - 11:35 AM
Trying to find an exhaust manifold to down pipe clamp that fits.
Going to get the cast version later today, hopely its a bit taller so as to properly catch both the manifold and downpipe flange.
#9457
Posted 10 April 2024 - 02:20 PM
I had the same problem. What I found was that there was an extra collar of metal around the end of the exhaust pipe creating a double thickness flange. Removing this then meant that I had a perfect fit with either type of clamp.
#9458
Posted 17 April 2024 - 03:30 PM
So after replacing the defective CV boots, CV joints, brake discs and changing the oil and filter I took it out for a run and all seemed fine until the right hand rear indicator stopped working, on investgation the lampholder had corroded, luckily I had kept the old lamp assembly as the new one is less than 2 years old, I then noticed that my brake lights were not working, it turns out that the brake light switch needs replacing, so that's my next task..
#9459
Posted 17 April 2024 - 04:39 PM
After finally getting the carpets in I fitted the rear speaker panel with some 6x9s - it's a tight squeeze as the Optimise carpets have a thick foam backing but just about managed to get them all in and secure.
20240417_171612.jpg 88.37K
6 downloads
#9460
Posted 17 April 2024 - 08:46 PM
Checked the piece of paper underneath mini in my garage after work. Annoyingly, still weeping oil from gearbox! It had new oil seals when work was done last week with my mini guy, while in for welding, and will now need to go back. Maybe a bad batch of seals from the shelf, or they didn't put them on properly? Hummm.... All under warranty, though.
wouldn't be a real mini if it didn't leak some oil !!!!
Allan
#9461
Posted 17 April 2024 - 08:48 PM
good job done there, looks very posh.
Allan
#9462
Posted 17 April 2024 - 08:57 PM
fitted new valve stem oil seals in hope that it will stop the smoke when first starting up after standing overnight, head back on tomorrow ,fingers crossed.
Allan
#9463
Posted 19 April 2024 - 10:25 AM
refitted dash and full service and tune ready for mot now not cranking, typical mini.
#9464
Posted 20 April 2024 - 11:24 AM
#9465
Posted 24 April 2024 - 07:16 AM
Ordered new part from Mini Spares.
In my spares box, I have a new rack and new wheelboxes, but the existing ones look fine so I'm thinking I'll just leave alone...
