9771 replies to this topic
#9436 Davidmt
Davidmt
  • 219 posts
Posted 10 March 2024 - 07:22 PM
Finally tackled the driver's door which had been removed some time since - drilled holes for a wiring loom (electric window and central locking plus lights - puddle light and door open warning light),  There's not much room in the door and the glass takes up most the space so the wire routing is fun!  One side now done and all wired up so now need to drill a hole in the A pillar for the wires and put the door back on - think I will follow the hingles and run a tube into the engine bay or footwell.  Then to start on the other side and to decide where to fit the relays and wiring etc.
Attached File  20240310_191309.jpg   54.47K   2 downloads
Attached File  20240310_191318.jpg   36.7K   1 downloads
Attached File  20240310_191332.jpg   44.02K   2 downloads
Attached File  20240310_191342.jpg   52.82K   2 downloads
#9437 Bobbins
Bobbins
  • 1,504 posts
Posted 10 March 2024 - 07:27 PM
Fitted an alternative style fog light, now I just need to source a glass lens ….
#9438 Davidmt
Davidmt
  • 219 posts
Posted 10 March 2024 - 07:57 PM
Snap - I just bought a clear unit from eBay and used a Red LED bulb - same as the brakes.
Attached File  20231211_172620.jpg   83.82K   0 downloads
#9439 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 12 March 2024 - 08:34 AM
Added cruise control through the haltech ecu! Motorways are so much easier now 😂
#9440 R32Egor
R32Egor
  • 313 posts
Posted 23 March 2024 - 03:31 PM
Cut pieces off my mini!
#9441 Aly-g
Aly-g
  • 459 posts
  • Local Club: Still looking
Posted 23 March 2024 - 11:19 PM
Fitted soundproofing to the under bonnet.
I've found doing this makes the car a lot quieter,
Allan
#9442 GT Jimmy
GT Jimmy
  • 1,646 posts
  • Local Club: S.U.N.M.C
Posted 24 March 2024 - 04:45 PM
In the quest to rid the GT of its annoying misfire fitted a new coil and took it for a blast round some country lanes. Pleased to report it's now running well
#9443 Aly-g
Aly-g
  • 459 posts
Posted 25 March 2024 - 12:00 PM
I bet that was a big chore for you blasting round the country lanes in a mini !
#9444 GT Jimmy
GT Jimmy
  • 1,646 posts
Posted 25 March 2024 - 12:03 PM
Was a long test drive lol
#9445 RichMPiBlue
RichMPiBlue
  • 471 posts
Posted 25 March 2024 - 08:05 PM
Picked it up from the garage after having a new passenger side floor panel welded in. I also had fitted new o/s + n/s driveshaft oil seals and a gearbox selector oil seal.
I thought it would only go in for a small patch up weld, lol!  :ghost:
#9446 roblightbody
roblightbody
  • 448 posts
Posted 30 March 2024 - 05:32 PM
I've been watching this topic for months, and never had anything to say because my poor wee mini was stuck in its carcoon, awaiting some spring TLC.
Well today I've been bombing about it in it, absolutely having a ball.  Main achievement of today was fixing the cigar lighter.  I'd been using a tyre inflator to pump up a soft tyre, and it had killed the cigar lighter.  Turns out it had melted the in-line fuse holder, which for some reason had a 35A fuse in it...  I've replaced the fuse holder, fitted a more suitable 20A fuse, and all is good again!
#9447 RichMPiBlue
RichMPiBlue
  • 471 posts
Posted 31 March 2024 - 07:43 PM
Checked the piece of paper underneath mini in my garage after work. Annoyingly, still weeping oil from gearbox! It had new oil seals when work was done last week with my mini guy, while in for welding, and will now need to go back. Maybe a bad batch of seals from the shelf, or they didn't put them on properly? Hummm.... All under warranty, though.
Edited by RichMPiBlue, 01 April 2024 - 05:31 PM.
#9448 Davidmt
Davidmt
  • 219 posts
Posted 02 April 2024 - 03:51 PM
Got some bling to fit to my car - looks good.  May get some more bits done!
Attached File  Bling.jpg   45.54K   2 downloads
#9449 Bobbins
Bobbins
  • 1,504 posts
Posted 02 April 2024 - 08:37 PM
I ate it …
#9450 Lplus
Lplus
  • 911 posts
Posted 07 April 2024 - 04:22 PM
Replaced the petrol tank, due to rust inside it due to condensation.
6 user(s) are reading this topic
    Bing (2)
