Edited by Bobbins, 28 January 2024 - 06:44 PM.
Posted 28 January 2024 - 06:13 PM
Posted 30 January 2024 - 01:36 PM
Popped out to give the oil a chance to get up to temperature and what should be going down the road in front of me?
Posted 30 January 2024 - 04:45 PM
LIfted the carpet to replace the crossmember - the floor was not in great condition so decided to bite the bullet and do the job properly. Temporarily a Flintmobile .
Flintstones..jpg 51.95K
7 downloads
Posted 05 February 2024 - 04:23 PM
Lowered the dash and put in the correct Mpi oil/volt gauges. Waiting for loom to arrive, hopefully this week(?), and will then put it all back together. However, bloody minis! Found out I need a small hole welding on drivers side footwell, new brake shoes and a slave cylinder for rear drivers side wheel.
Ah well could be worse, lol!
Posted 05 February 2024 - 04:33 PM
Found out I need a small hole welding on drivers side footwell.
That's how mine started....photo above
Posted 05 February 2024 - 05:46 PM
Interesting... That makes two of us!
Posted 06 February 2024 - 07:13 PM
Fitted new shoes and rear brake wheel cylinder to drivers side.
Posted 06 February 2024 - 09:02 PM
Posted 06 February 2024 - 09:18 PM
Had the Mini delivered back after having the crossmember replaced and new floor panel welded in to fill the hole posted above. Good job
Looks great. Got mine booked in for welding on the 26th.
Posted 08 February 2024 - 01:30 PM
Posted 08 February 2024 - 08:55 PM
Posted 09 February 2024 - 07:51 AM
Posted 09 February 2024 - 11:38 AM
Respect to those who did this every day for a job.Steve..
Absolutely!
Posted 12 February 2024 - 04:31 PM
Fitted the new rear wheel cylinder and brake shoes to the passenger side, stopped a weeping issue by adding new thermostat gaskets and wired Mpi volt and oil clocks in.
Had a wiring issue which had me pulling my hair out for a few hours. Finally sorted the bugger out in the end, mind.
Edited by RichMPiBlue, 12 February 2024 - 06:46 PM.
Posted 14 February 2024 - 07:03 PM
Adjusted and fitted the dash back together. Which I did better than ever this time as I made some adjustments, and added some new fuses.
