9771 replies to this topic
#9301 Designer
Designer
  • 613 posts
  • Local Club: LSMOC
Posted 13 August 2023 - 09:16 AM
There's actually one more in the back and one outside
Are you planning another but bigger Italian Job then :D  :D  :D  :D  :D
#9302 MacGyver
MacGyver
  • 1,027 posts
Posted 13 August 2023 - 11:34 AM
Could be... 😏
#9303 bluequinn
bluequinn
  • 105 posts
Posted 13 August 2023 - 03:39 PM
My historic registration arrived, along with my black and silver plates, so I fitted them.
They look so much better on a black car!
#9304 RichMPiBlue
RichMPiBlue
  • 471 posts
Posted 15 August 2023 - 03:26 PM
Took it for its MOT and it passed with flying colours! No advisories either ... Thought I was dreaming, lol!
#9305 postve
postve
  • 577 posts
Posted 15 August 2023 - 03:29 PM
Replacing my timing chain gasket - why would this fall apart - possibly not enough lubrication? I replaced my crank pulley 2 months ago and did not touch it. The last time I changed to a new gasket was 2 years ago?
Referring to the donut that encircles the crank shaft and at bottom of timing chain cover
Edited by postve, 15 August 2023 - 03:31 PM.
#9306 bluequinn
bluequinn
  • 105 posts
Posted 15 August 2023 - 03:57 PM
My driver's side (left) vent has never blown cool air, and I discovered that the pipe to it was cut off halfway, and the little scoop for the grille was missing. Thus it was only ever getting hot air from the rad. All the UK shops list the plastic scoop as NLA but Datch.fr in France had one. The hose is also NLA from everywhere except Rimmer Bros. They sent me a length of an alternative hose, narrower than the original but with an internal diameter similar to the foam inside the old one. It fits inside the vent and scoop rather than outside, but seems to work.
So grille off, wheel off, and I fitted all that, and now I should have fresh air.
And then I discovered the battery was flat, so on the charger it's gone.
#9307 Lplus
Lplus
  • 911 posts
Posted 16 August 2023 - 12:59 PM
Fitted a new steering rack to the clubman estate yesterday, and today took the carb off again to sort out the leaking float valve. :xxx:  Next to sort out the tracking properly.
#9308 Verderad
Verderad
  • 413 posts
Posted 16 August 2023 - 02:53 PM
Broke the windscreen!!
Its now that I realise I should have put the screen in before sending to paint.
Nagging feeling that the aperture after new scuttle in a little tight.
Cannot get the top right hand corner into the rubber.
#9309 colinf1
colinf1
  • 1,026 posts
Posted 18 August 2023 - 08:02 PM
Tightened up the bottom radiator bolt, then done a tightness check on all bolts on front subframe, all good.
Had a rattle in the interior of the car, passenger side rear door bin area, emptied it out and run my hand around to look for anything loose, got my finger jagged by a piece of welding wire that I missed on the clean up!
Refitted grille with an extra bolt on passenger side, it was a bit rattly, sorted now.
#9310 cooperd70
cooperd70
  • 730 posts
Posted 29 August 2023 - 04:40 PM
Took the little car for it's MOT and passed with no advisories 👍👍
#9311 chuee
chuee
  • 176 posts
Posted 30 August 2023 - 11:05 AM
checked the timing curve on the Metro-donor electronic distributor.
#9312 whistler
whistler
  • 1,818 posts
Posted 30 August 2023 - 02:37 PM
Left the car in a brick garage for 40 years and lost the v5.
#9313 chuee
chuee
  • 176 posts
Posted 30 August 2023 - 03:08 PM
  • Screwed in both check arm grommets.
  • With a syringe, dripped a little  phosporic acid down the d/s front seam finisher;  a kind of slushing oil component. It should mix nicely  with the  sticky coach enamel in there.
  • Sniffed the air in the cabin  after burning incense in there yesterday; confirmed lovely.
#9314 chuee
chuee
  • 176 posts
Posted 30 August 2023 - 03:14 PM
Really? Surely not before a complete  paint job?
I use an 8" stick, about 9mm thick, cut at an angle and smoothed off,  to push the rubber lip over , pushing form the inside, whilst holding the screen on the outside. A little mist of water for lubrication. And I'm talking about with a new seal. Take a good firm push but no risk of cracking glass.
The stick actually has a stump of a fork left at its end where the cut it in one place  and that provides a better handle for applying and directing force to the rubber.
|I recall a chap soaking his seal in warm water forst to make it more pliable. But I didn't so that , it was a warm day.  Handy to have a helper steady the glass from outside, but I didn't myself. I would prefer that though.
Also, as I recall from  quite recently,  I started at bottom middle, worked up oneside to  top misddle, then the other side... so the corners were not left until last, but a section of top middle. That gives a little more piability at those tougher areas.
I am assuming you are fitting the seal to the car frame first , then the glass to the seal in position.
Edited by chuee, 30 August 2023 - 03:17 PM.
#9315 KTS
KTS
  • 2,459 posts
Posted 30 August 2023 - 03:18 PM
i suspect he meant trial fit the screen before painting
