9724 replies to this topic
#916 Cooperman
  • 23,278 posts
Posted 04 April 2011 - 04:51 PM
Sorted out a sticking choke on the RH carb on the Cooper 'S' as it was causing nos 1 & 2 plugs to soot-up.
Runs great again now.
#917 steverose
steverose
  • 229 posts
Posted 04 April 2011 - 07:12 PM
Trial fitted the mini into the van and it fits ;) happy days
wow! I like that :genius: :thumbsup:
Im very impressed.....A quick question. How are you going to secure the car in the van. Will it need tied down or can you just use the hand brake.
You couldnt put the hand brake on as you need to winch the car in as you cant get in our out the door when its in. There are already a few mounting points at the rear, I have got to fit a few more at the front so it will have be tied down at each wheel. I will also be fitting chocks in which will block each wheel front and back. As has been said it would hurt if you brake hard ;)
Should have its first run out later in the month at Oulton park.
#918 myminimonster
myminimonster
  • 72 posts
  • Local Club: great minis
Posted 04 April 2011 - 09:12 PM
Well I had a very tedious weekend.
On the Wednesday I fitted my block to the gearbox and stuggled like buggery to carry it alone from the kitchen to the hall and then over the step onto the drive.
I then fitted the clutch on friday and with the girlfriend controlling the hoist we got the engine in the car. Its a remote gearbox so not the most amount of clearance.
Anyway left the engine plonked in till mates came over on Saturday. All the clutch is new including release bearing and also the plunger and the arm / pins the lot. We connected and blead the clutch before one of my mates through that the plunger was sticking a bit far out even when the clutch was pressed. To make sure I had not made a balls up we lifted it out again to check the flywheel was on the crank ok and that the release bearing was pressed on the plunger enough. Anyway all looked good so in it went again.
We proceeded then to carry on with the aux connections such as the new s brakes, the remote gearbox linkage and the dredded U links for the drive shafts. These were fun , NOT. So at this point we have been spannering for a few good hours and its getting on to 19:00pm. So this is where I made a big boo boo.....
I was fitting the dizzy drive gear and it slipped off my finger and dropped at a funny angle just in view, heading into the block and towards the sump.. :D
I could have cried.We spent 20 mins with a magnet on a rod thingy trying to fish it out but it was top heavy. I took my fuel pump blanking plate off and tried to fish it out from there, no joy. We then heard it drop a bit more. Turning the crank slowly it came into view before i knocked it to the dreadded sump. There was no options left now. :D
So we set in for a late one... Within 3 1/2 hours we had it out, on the floor, clutch off, block split from box, took the dizzy gear out and fitted it at this point, put it all back together and got it in the car. Sunday was spent putting the U joints back on and continuing where we were 24hrs before. Anyway so far so good now. Making good progress in an attempt to get her ready for IMM.
Picked up my machined head today that have had hardned seats fitted and valves lapped. I asseembled the springs and seals and painted the head tonight.
Also listed my other mini 1380 in the for sale section on TMF
Not long left now till IMM and lots to do.
I have put the dizzy gear in ample of times before without issues and now i know why. I was informed today that you can only drop the gear in on an a series block and not a a+. This is my first a series as all others have been a+ , hence the issue. Be warned. I also found out the dizzy drive is threadded in the middle so you can wind a bolt in it and then poke it home :angry:
Adie
#919 mymini007
mymini007
  • 2,046 posts
Posted 04 April 2011 - 09:33 PM
I started mine :D
First turn of the key, after 5 months sat up for winter :D
#920 retroracer1275
retroracer1275
  • 543 posts
Posted 04 April 2011 - 09:37 PM
fitted a new tank, braided fuel line, battery cables (incar) battery box etc etc
#921 DaveVader
DaveVader
  • 942 posts
Posted 04 April 2011 - 09:55 PM
Fitted my wheels and arches. Pictures tomorrow as this mini is a bit of a secret with my local lot.
#922 1984mini25
1984mini25
  • 8,784 posts
Posted 04 April 2011 - 09:58 PM
Replaced a knackered wheel bearing that had no effect and didn’t fix the problem. :D
#923 samsfern
samsfern
  • 5,243 posts
Posted 04 April 2011 - 10:03 PM
developed a fuel leak at the weekend, so investigated it today, it was the rubber seal in the float chamber, that holds the jet in, so replaced the seals and jets on both carbs, done both just to be on the safe side. Also fitted new brake discs and pads.
#924 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 04 April 2011 - 10:06 PM
i broke this
trying to get the roll pin out!!!
#925 DaveVader
DaveVader
  • 942 posts
Posted 05 April 2011 - 09:04 PM
As promised...
Mine is the big yellow thing.
10*5.5" Wellers (still need another coat of paint or two) covered in 165, 70, R10 A008s, shielded by group 2 arches.
Harvey (as he is affectionately named) is the new addition to my mini family, he has had a few issues so far but I'm loving him!
Few more pics for luck...
#926 Ames
Ames
  • 36 posts
Posted 05 April 2011 - 11:38 PM
She got a flat tyre which put her in lots of trouble with me
#927 shed
shed
  • 594 posts
Posted 06 April 2011 - 02:08 AM
really need to get a star washer thingy to put the door barrel back in. might attempt it today.
#928 samsfern
samsfern
  • 5,243 posts
Posted 06 April 2011 - 08:52 PM
clutch release bearing disintergrated and locked up this morning, so i drove her to work with no clutch, which was fun in stop start morning traffic, not, wasnt actually too bad once id started moving, other then the pillock sitting on my bumper flashing his light whilst i was struggling to get her into 3rd gear, which involved lots of synchronised crunching and swearing :D i enjoyed driving it with no clutch, bit of different experience, knocking it into neutral, matching the revs to the road speed, and slipping it into gear, feels good when you do it with no crunching.
#929 Scallywag630
Scallywag630
  • 2,850 posts
Posted 06 April 2011 - 09:01 PM
Did to her what she loves.....a thrash arround deserted country lanes....magic.
#930 Jaswalker24
Jaswalker24
  • 113 posts
Posted 06 April 2011 - 09:17 PM
started cleaning the radius arms and the back plates :thumbsup: got scratches on my arms from the wire brush :D
