Cut off some of the inner wings to give it a solid try to mount the new CGA3 subframe. Still a tight fit though, so gonna chop some more and try again.
#9256
Posted 22 June 2023 - 04:07 PM
#9257
Posted 24 June 2023 - 10:33 AM
Fitted a new fuel level sender unit, and changed the boring black wipers for shiny stainless ones from Minispares.
Posted 24 June 2023 - 05:06 PM
Went for a little drive……ran out of fuel, despite the fuel gauge saying three quarters full.
Half a Jerry can later, she fires up.
Guess what I’ll be doing this weekend!
#9259
Posted 24 June 2023 - 06:46 PM
#9260
Posted 24 June 2023 - 08:05 PM
Missed Moffat this year
#9261
Posted 25 June 2023 - 05:56 PM
Removed the fuel tank sender after yesterday’s running out of fuel episode.
Couldn’t see anything obvious that was getting stuck in the tank.
Checked the movement of the float arm - all seemed well.
Put it back together & the gauge seems to be working- reads low now (always read three quarters full).
Gotta love Minis!
#9262
Posted 26 June 2023 - 10:24 AM
First little jobs on our 2000 cooper.
Boot wasn't locking. Stripped the lock down to find that the little "nipple" on the end of the lock barrel had sheared off. Cleaned up all the crud on the mechanism and replacement lock set ordered from minispares, plus new seal.
Also corrected the interior door pull. One was pointing up, one was pointing down. Both now pointing up.
Windows are next on my hit list, both mechanisms are stiff and I can hear a grinding noise when I'm winding down the last couple of inches so I suspect there is a bit of corrosion going on there.
#9263
Posted 26 June 2023 - 07:18 PM
Took the K&N's off and fitted an MED twin HS4 filter and stub stack. The stub stacks are so much nicer than the K&N's.
However, the thread decided to remove itself on one of the carbs so had to pull it out and use a bolt to attach the back plate!
#9264
Posted 27 June 2023 - 11:38 AM
Finished fitting the new braided Pressure Gauge pipe, and took it for a 24 mile test drive. All sorted now, and no sign of an oil leak.....
#9265
Posted 30 June 2023 - 04:02 PM
Dropped off the Mini yesterday to get the engine set up correctly.
Took it to Ron Harper Classic Sports who has been tuning engines & particularly carbs for many many years.
What he doesn’t know about carbs isn’t worth knowing about.
Anyway, ignition timing checked & adjusted, compression checked & all good. The carb needle that was already in, was too weak. So new BDR needle fitted, mixture adjusted, idle adjusted, CO2 checked, HC checked.
He advised that the BP7ES spark plugs fitted were too cold for the engine spec, and better off using BP6ES spark plugs (unless using on the track).
And lastly he advised the battery wasn’t getting any charge, which likely down to faulty alternator.
All work carried out was written down for both his & my records.
The car runs like dream now.
Edited by Readers14, 30 June 2023 - 04:05 PM.
#9266
Posted 01 July 2023 - 11:46 AM
Replaced the K&N Cone filters with some lovely MED stub stacks and filter
#9267
Posted 01 July 2023 - 02:47 PM
Shooter
#9268
Posted 01 July 2023 - 03:56 PM
They are lovely.
I have the single one for the HIF44. Nice bit of kit.
#9269
Posted 01 July 2023 - 06:19 PM
They are lovely.
I was amazed how different they are to the k and n ones.
#9270
Posted 01 July 2023 - 06:49 PM
Edited by imack, 01 July 2023 - 06:57 PM.
Bing (1)
