9772 replies to this topic
#9226 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 23 May 2023 - 05:58 PM
Replaced the seals in the clutch master cylinder. AAARRRRGGGHH Got the split pin and pin out without too much trouble after removing the front seats, the column and the heater/air pipes, but I had to make up a special clamp/holder to get the new pin back in and opening the new split pin was a nightmare. The fork needed a bit of welding to make the hole round again. The bloke who put them in at the factory must have been paid well and been a contortionist to boot.
I fit a R clip to the clevis pins for ease of removal
#9227 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 23 May 2023 - 06:38 PM
Replaced my cracked nearside rear lens with one I bought for £2, at the L2B in Brighton.
#9228 Lplus
Lplus
  • 911 posts
Posted 23 May 2023 - 07:53 PM
I tried that but there was too much  chance of the end of the clip touching the frame and preventing the clutch returning fully.  Maybe you have smaller R clips.
#9229 Lplus
Lplus
  • 911 posts
Posted 24 May 2023 - 07:59 PM
Just about to swap the estate for the saloon at the other garage and discovered the indicators had stopped working, so returned home to investigate.  Blown fuse, plus the brake light switch was broken and a brake light bulb was dead (same circuit).  Minispares order in and now waiting for the switch.  I may have damaged the switch removing/replacing the clutch master cyl... :shy:
#9230 minijules92
minijules92
    Starting My Mini Up
  • 4 posts
Posted 26 May 2023 - 04:33 PM
Took the interior out, bonnet, boot, fuel tank out, arches off, windscreen, back and side glass, most of the engine bay except engine itself (need to borrow a hoist) BIG DAY. Revealed not as much corrosion as I thought I would.......for now!
#9231 J808
J808
  • 34 posts
  • Local Club: LSMOC
Posted 31 May 2023 - 12:16 PM
new brake shoes fitted, a new rear brake cylinder as one ram was rusted solid, stepper motor and idle reset and MOT passed so good for another year
#9232 montyc
montyc
  • 308 posts
Posted 31 May 2023 - 06:53 PM
Played with the mixture settings on my carb, hopefully that helps start to sort my running issues. Did a coolant flush and re-fill, ordered a boat load of service parts to do a full service, clean my tank and fit a fuel filter before the carb... Just need to wait and see if any of that stuff sorts my problems out. If not then it'll be off for a timing check at the garage
#9233 MattMini94
MattMini94
  • 46 posts
  • Local Club: London Surrey Mini Owners Club
Posted 03 June 2023 - 04:20 PM
Fitted the Rostyle wheels with the new Yokohama tyres which gave me an excuse to go for a bit of a drive😂
Attached File  IMG_20230603_162425_478~2.jpg   76.28K   4 downloadsAttached File  IMG_20230603_162443_985~2.jpg   50.23K   5 downloadsAttached File  IMG_20230603_162456_057~2.jpg   93.22K   4 downloadsAttached File  IMG_20230603_162513_749~2.jpg   98.66K   1 downloadsAttached File  IMG_20230603_162518_608~2.jpg   100.72K   6 downloads
#9234 Readers14
Readers14
  • 441 posts
Posted 03 June 2023 - 06:30 PM
Connected the battery, turned the key & started up first time.
Pulled her out of the garage, washed & detailed the paintwork.
Looks stunning in the sunshine
Booked her in for an MOT for next Friday.
#9235 GT Jimmy
GT Jimmy
  • 1,646 posts
  • Local Club: S.U.N.M.C
Posted 03 June 2023 - 07:20 PM
Fitted a new rad top bracket after the original one snapped, probably due to not fitting the rubber washers and sleeves first time round, doh! While I was there fitted a new earth strap and vac pipe
#9236 Shooter63
Shooter63
  • 1,066 posts
Posted 03 June 2023 - 07:22 PM
Spent 2 hours honing a cam gear and polishing a camshaft so they would actually fit together without needing to use a sodding lump hammer to assemble them, went to start timing the cam in only to find my degree wheel has cracked, disassembled the oil pump to find its well within tolerance ( Result) went to put it to find the bolts are miles too long.so a mixed bag sort of a day really.
Shooter
#9237 YJO
YJO
  • Just Joined
  • 49 posts
Posted 05 June 2023 - 01:07 PM
Annual oil change the other week, then expansion tank decided to bubble and overflow….. panic and time consuming thoughts then passed, and changed the thermostat and sensor, now as good as ever, so luckily not the head gasket or pump.
A good flush is due anyway so that’s next weekend’s job ,and maybe a pump change as a winter job as i bought one as a precaution as I was passing mini spares last week.
#9238 Shooter63
Shooter63
  • 1,066 posts
Posted 05 June 2023 - 07:31 PM
Took the Mk1 out for a blast ( well trundle) and I'm pretty sure at one point we nearly breached the 60 mph mark ( down hill, following wind) pumped the tyres up and filled the tank
Shooter
#9239 bluequinn
bluequinn
  • 105 posts
Posted 05 June 2023 - 08:30 PM
Took some photos for my application to FFVE which will allow me to register it as a 'vehicule de collection', which means I can have black and silver plates, and only take it for a CT every 5 years. Being a black car it will just look cooler with the old style plates.
The copy of this month's L'Equipe Le Mans special is necessary to prove when the photos were taken. A lot of people were registering highly modified vehicles using old photos.
#9240 MattMini94
MattMini94
  • 46 posts
Posted 06 June 2023 - 07:41 PM
After polishing my dad's car in exchange for him doing some bit on the Mini whilst I was working, I decided it was the Mini's turn, so she was hand polished followed by 2 coats of Soft 99 wax. Then fitted new door seals as the old ones were a bit shot, also ordered all things needed for 7.5 disc conversion😁
Attached File  IMG_20230606_193251_879~2.jpg   59.48K   3 downloads
Attached File  IMG_20230606_193302_264~2.jpg   68.98K   2 downloadsAttached File  IMG_20230606_193334_017~2.jpg   86.49K   6 downloads
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
