Took the pistons out of my mini clubman 1098 engine. 15 thou clearance between top of piston and bore at half stroke and the oil control rings had no tension at all. No wonder it was smoking so badly.
#9181
Posted 04 March 2023 - 01:35 PM
#9182
Posted 13 March 2023 - 01:39 PM
looked longingly at it in the garage while collecting DIY materials to follow orders from SWMBO
#9183
Posted 13 March 2023 - 03:51 PM
Uncovered it and woke it from its winter sleep, battery dead so just pushed it out from its resting place.
Had a look over and inspected suspected problems ready for the summer and ended up with a £600 mini spares order
Hopefully everything will be good for IMM 2023
Edited by R32Egor, 13 March 2023 - 03:52 PM.
#9184
Posted 16 March 2023 - 06:03 PM
Investigated the mileometer on the clubman estate to see why it doesn't advance. Couldn't see anything obvious. Checked the lights after instrument refit and found they went dead. Much puzzling, with voltage at the switch, good switch connections and resistance on the downstream wires as well. Traced to corroded contacts on the fuse box. allowing voltage but not current on the input wire....
#9185
Posted 16 March 2023 - 08:22 PM
Apparently it's not acceptable to close one eye, look down the side of the car, then close the other to look down the other side when setting the car up to check the tracking. What idiot would do that lol
#9186
Posted 16 March 2023 - 08:58 PM
Had a new tyre fitted to the nearside front on the GT
When am I setting it up aha
#9187
Posted 16 March 2023 - 09:16 PM
Tesla rates?When am I setting it up ahaHad a new tyre fitted to the nearside front on the GT
Edited by GT Jimmy, 16 March 2023 - 09:16 PM.
#9188
Posted 17 March 2023 - 09:28 AM
#9189
Posted 17 March 2023 - 01:05 PM
Tesla rates?
Haha don't worry, pasty barm rates ;)
#9190
Posted 17 March 2023 - 10:50 PM
#9191
#9192
Posted 24 March 2023 - 06:23 PM
After 2 years of not doing anything to the Mini…….. I took the storage cover off & smiled.
#9193
Posted 09 April 2023 - 02:54 PM
#9194
Posted 09 April 2023 - 03:23 PM
Newly installed oil pressure gauge sensor doesn't seem totally compatible with the existing gauge,reads near enough 80psi most of the time so I'll swap the gauge out for the one that came with the sensor
#9195
Posted 10 April 2023 - 10:52 AM
In the past week, its been brought out of winter hibernation, and has been started to be used. I had it MOTd and serviced before putting it away for the winter, which has turned out to be a good idea.
A commute to work on Friday was fun - but it was a frosty start with a frozen windscreen, which I don't think I've done in a Mini for many years. The heater soon got going though. The roads are horrific around here just now, which spoils the fun a bit, and you end up staring at the road surface instead of looking further ahead. Some of the most fun roads are simply no-go, due to the incredibly rough surfaces. The very same roads that I enjoyed as a youngster in minis in the 90s.
All good so far, although as usual I feel like the car has shrunk.... a combination of other cars getting much larger, at the same time as I've unfortunately got larger... !
There's a great big long to-do list in my head, but its all things that aren't essential to just getting out and enjoying it for a while.
Edited by roblightbody, 10 April 2023 - 10:59 AM.
