9720 replies to this topic
#9106 Quinlan minor
Quinlan minor
  • 1,169 posts
  • Local Club: LSMOC
Posted 09 October 2022 - 03:06 PM
Fitted a couple of gel pads in the driver's seat squab to add a bit of comfort.
https://www.ebay.co....ar=443894959493
Big improvement.
#9107 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 09 October 2022 - 03:26 PM
Big improvement.
Now that's a useful tip, I have been thinking of re-foaming my seats,.. maybe these pads are a good idea too... Did you slide it into/under the seat cover?
#9108 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 09 October 2022 - 04:06 PM
Gave it a good polish and went to Torque Moto for a mini day
#9109 Mini Waco
Mini Waco
  • 438 posts
Posted 09 October 2022 - 05:22 PM
Big improvement.
Awesome…. Great idea
#9110 Quinlan minor
Quinlan minor
  • 1,169 posts
  • Local Club: LSMOC
Posted 09 October 2022 - 06:29 PM
Big improvement.
My seats have the seat cover wired into the foam, so I had to fit it under the foam.
#9111 Lplus
Lplus
  • 888 posts
Posted 09 October 2022 - 07:55 PM
Changed the cylinder head on the 1293 saloon.  Now the previous head can be given the once over, new guides etc.
#9112 Verderad
Verderad
  • 411 posts
Posted 09 October 2022 - 09:52 PM
Refurbished the door lock mechanism. Sand, prime, paint.
Cleaned the garage, put tools away and looked at the box of miispares bits and bobs before next order.
#9113 petey81
petey81
  • 1,316 posts
Posted 09 October 2022 - 10:11 PM
Fitted a new gear linkage seal kit and checked no bolts were seized before fitting a new steering rack on Thursday
#9114 57gow
57gow
  • 13 posts
Posted 16 October 2022 - 08:14 AM
Moring All.
Yesterday fitted windscreen went in like a dream not a nightmare sealed all round and chrome strip fitted, today fitting newly painted wheel spats.
#9115 P1GLT
P1GLT
    Just On Tickover
  • 7 posts
Posted 16 October 2022 - 08:59 AM
Finally managed to get piglet out of the shed and removed the head to confirm another blown gasket. Sent the head off to the doctor for a checkup.
#9116 Cooperman
  • 23,273 posts
Posted 17 October 2022 - 08:56 PM
I drove my 1990 Cooper road-rally car for the first time since 2005, having bought it back in 2020 and completed a full resto.
It passed the MoT with no advisories. Just got to set the mixture which was leaned off to pass emissions test 😉. Then just got to run in the new rings and bearings and off we go
#9117 Clip
Clip
  • 185 posts
Posted 23 October 2022 - 07:45 AM
Checked my rear wheel camber and left wheel was spot on at -0.5 degrees, but right rear wheel had a positive camber of just over +1.5 degrees. So bought a camber adjustment bracket (the screw type not the ridged plate type). What a bloody pain. Firstly the two self tappers in the little side cover plate on the mini were seized and I had to grind and drill them out. Then when fitting the new bracket only two of the bolt holes lined up so that all could be fitted, including the radius arm bolt that was too big for the hole in the bracket. Had to open that up slightly, but more so on a couple of the other bolt holes. Not hard to do, but what should have been a quick job just turned into a swearing, frustrating session.
Edited by Clip, 23 October 2022 - 07:52 AM.
#9118 Icey
Icey
  • 1,551 posts
Posted 23 October 2022 - 07:26 PM
Not strictly for our Mini, but a pal (I know you lurk here sometimes, Mark!) asked for some replacement knobs (stop that sniggering) so I made some...
(excuse the chatter, my tiny lathe doesn't like radius cuts)
And with the original stickers on...
#9119 Tones61
Tones61
  • 428 posts
Posted 24 October 2022 - 12:05 PM
made up a nice big alloy heat shield between exh mani and 45 weber long inlet,
cant uploads pics as it keeps saying they're too large :-)
#9120 johnR
johnR
  • 2,297 posts
Posted 29 October 2022 - 09:25 PM
Took out the petrol tanks to access the wiring loom which is coming out for replacement - a right fiddle!
