9720 replies to this topic
#9076 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 16 August 2022 - 01:17 PM
Serviced steering rack
Have a brand new on FAM7306 in a box, bern in garage for 4 years a gift from a friend who bought it in 2015.
However it’s a LHD rack!! Wonder if minispares will exchange ?
If you cannot exchange it I may be interested in it. Of course the shipment over the channel may complicate things...
#9077 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 16 August 2022 - 02:24 PM
Yesterday I disloged these two guys out of their home since 1991.
Glad I did it on the bench. Maybe I should do it on Frankie also as the gears were not really clear, but is it possible to do on in situ? It seems to be really hard to do under the car...
Next step is to clean the housings and reassemble as soon as I order and receive the X-pin diff.
#9078 ClassicAsh
ClassicAsh
  • 139 posts
Posted 18 August 2022 - 05:14 PM
Heater was dripping fluid and on further inspection the matix has seen better days so ordered a new one along with a new thermostat housing, sandwich plate and gaskets as I noticed a slight leak form there the other day and it wasn't in the best of condition when i rebuilt it a while ago so while i am draining things down i might as well tick that off the list. Might as well give it a service as well while i am in the workshop.... ahhhh workshop time.... is it odd that i enjoy it.?
#9079 Lplus
Lplus
  • 888 posts
Posted 21 August 2022 - 10:43 AM
Yesterday replaced the clutch slave cylinder seal and today sorted out the rear numberplate lights.
#9080 Abbot
Abbot
  • 105 posts
Posted 02 September 2022 - 08:18 PM
I spent most of the afternoon trying to fit the engine mounting bolts.  Hands are too big, fingers too short.
#9081 Hamstein
Hamstein
  • Just Joined
  • 107 posts
Posted 02 September 2022 - 09:42 PM
Got the front end finished, at last! - now I can spin it round in the garage and start replacing the back end! - Gaaahhhh, it never ends! :proud:
#9082 Aly-g
Aly-g
  • 456 posts
  • Local Club: Still looking
Posted 02 September 2022 - 10:54 PM
Checked valve clearances, fitted new alloy valve cover , changed oil and filter, fitted new homemade sun visors, made of leather and foam board all hand stitched by myself. Off to Redbourn car show Saturday then Capel manor Sunday.
#9083 Verderad
Verderad
  • 411 posts
Posted 03 September 2022 - 08:40 PM
Cut some foam, 6 cuts to be exact and a lot of time just looking.
#9084 57gow
57gow
  • 13 posts
Posted 04 September 2022 - 02:23 PM
Afternoon. Replaced water pump,fan belt,thermostat and new coolent as weter pump was leaking after test drive all is well.
#9085 Clip
Clip
  • 185 posts
Posted 07 September 2022 - 01:06 PM
After lining the firewall on the engine side plus underneath the bonnet, I spent the day pulling out the dash and front carpets and fitting sound deadening and then sound absorbing materials to all surfaces. Made bugger-all difference to the noise levels and probably added about 10 kilos in weight!
#9086 cooperd70
cooperd70
  • 726 posts
Posted 07 September 2022 - 01:40 PM
Took her for an MOT and had a clean pass! πŸ™‚πŸ™‚
#9087 Abbot
Abbot
  • 105 posts
Posted 07 September 2022 - 05:08 PM
Just finished refurbishing my SU HS4 carburettor.  Spent a lot of time worrying about and researching if I needed to rebus the spindle.  Finally decided to dismantle and check.  It was clear that there was wear on the spindle so fitting a new one felt OK so have gone with that.
#9088 bangermadness08
bangermadness08
  • 257 posts
Posted 10 September 2022 - 08:42 AM
What foam did you use for the bulk head? I’m needing some after replacing the brittle rover one but it’s a mine field of which one is right for the job
#9089 57gow
57gow
  • 13 posts
Posted 15 September 2022 - 10:16 AM
Hi, This week I have the week off what have done.
No 1 Replaced drivers seat base foam and diaphram
No 2 Windscreen out bonnet off sucttle rubbed down and painted
No 3  New wheel arches spats painted body colour brg
I will leave the windscreen a while before refitting to let the paint fully dry.
#9090 petey81
petey81
  • 1,316 posts
Posted 20 September 2022 - 02:47 PM
Replaced crack fuel hose which lasted 8 months!! Replaced rear knuckles and installed new headlight connectors.
