9720 replies to this topic
#9061 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 26 July 2022 - 07:05 PM
Continued on rebuilding my Gearbox I will use for the project.
played a bit with the synchro hubs before installing the laygear. Resulting in 3 balls and their spring to wander around (luckily inside the box). Did not knew that the synchro hub is blocked only later by the layshaft...
Tried to reinstall the balls in situ, no success yet.
Checked the clearance between the lyshaft and the housing, and ordered shims at Guessworks. And three new springs as the new one show already some wear. Bugger.
..it's a bugger to get them back in with the shaft installed.  my tip is to use a tie wrap around the synchro hub to hold the balls/springs in place, then slide the collar back over
Hehe, this is what I was thinking about :)
Will continue as soon as the delivery from Guessworks arrives. I will try to get them back on in position. Otherwise I will need to remove the shaft...
Today I had the clever idea of cleaning the threads for the speedo drive cover as there was some gasket paste leftovers. It crunched a lot and there was a lot of dirt in the threads.
Then I remembered I sandblasted the case with glass media (I covered all the openings with specially cut cardboards and sticked them with duck tape) Still a lot of dirt in the box I had to clean afterwards but I did not thought about the threads.
It's incredible where the glass media can go...
#9062 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 30 July 2022 - 07:10 PM
Refitted gas tank and took a drive. RPMs are quite low, need to troubleshoot. I stalled when I came to.a stop at a stop sign.
#9063 RichMPiBlue
RichMPiBlue
  • 449 posts
Posted 02 August 2022 - 02:39 PM
Fitted the new steering wheel.
Whats-App-Image-2022-08-02-at-1-18-56-PM
#9064 Tones61
Tones61
  • 428 posts
Posted 02 August 2022 - 05:01 PM
Awesome buddy,looks well smart,
Nice one ;-)
#9065 RichMPiBlue
RichMPiBlue
  • 449 posts
Posted 02 August 2022 - 05:22 PM
Nice one ;-)
Cheers!
#9066 RichMPiBlue
RichMPiBlue
  • 449 posts
Posted 05 August 2022 - 11:20 AM
Prepping the mini for Brands Hatch Mini Festival this Sunday.
Edited by RichMPiBlue, 05 August 2022 - 11:20 AM.
#9067 mini-mad-mark
mini-mad-mark
  • 849 posts
  • Local Club: northants wot no brakes
Posted 05 August 2022 - 09:34 PM
I was replacing these:
Attached File  20220805_212000.jpg   54.78K   4 downloads
Crackerjack pencil for the first correct answer.......
#9068 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 06 August 2022 - 06:54 AM
Engine steady bushing?
#9069 mini-mad-mark
mini-mad-mark
  • 849 posts
Posted 06 August 2022 - 10:30 PM
Bottom arm bush (RH/drivers side)
They must have been on the way out for some time but I only realised on Wednesday - just leaving a car show and the car suddenly shot across the road as if I had skidded on some oil.
Then carefully (!) trying it out, showed that after turning hard right the car would steer itself across the road (as the tie bar could move backwards and forwards of its own accord - very dodgy!)
#9070 riktanius
riktanius
  • 233 posts
Posted 08 August 2022 - 03:57 PM
Been getting to it lately...
Adjusted the Spax much softer and am trying to fix the ride height (still not great). Deleted the heater and removed the heater valve.
Taking the car in to get the carb redone and tuned a bit.
I've got a laundry list of things that I want to do, including an engine swap, full rewire, and restomod interior.
https://www.instagra...id=YmMyMTA2M2Y=
Edited by riktanius, 08 August 2022 - 03:57 PM.
#9071 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 09 August 2022 - 02:44 PM
Received the delivery from Guessworks (shims for the laygear and synchro springs).
Repaired my mistake from last week. Reinstalled the synchro hub at its place with the help of a hose clamp and three pins to push the balls further in the synchro.
Managed to make it work after a 2h battle.
Then I could go further and set the clearance on the laygear and finally install it together with the central oil pick-up.
Next is to recheck the clearance on the main bearing retainer and tighten everything.
I was so concentrated in this job that I forgot to have my dinner...
#9072 joyce1bro
joyce1bro
  • 231 posts
  • Local Club: Waikato Mini Club
Posted 12 August 2022 - 08:13 AM
Got these delivered all the way to New Zealand…. Thanks MED
#9073 RichMPiBlue
RichMPiBlue
  • 449 posts
Posted 12 August 2022 - 05:06 PM
Tracking and alignment.
A0-DF99-C8-895-E-4-E9-B-989-D-7011-B1-BB
Edited by RichMPiBlue, 12 August 2022 - 05:17 PM.
#9074 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 13 August 2022 - 01:53 PM
Installed the Aluminum Billet air box induction pipe S Works.
#9075 Verderad
Verderad
  • 411 posts
Posted 14 August 2022 - 11:56 AM
Serviced steering rack
Have a brand new on FAM7306 in a box, bern in garage for 4 years a gift from a friend who bought it in 2015.
However it’s a LHD rack!! Wonder if minispares will exchange ?
