9720 replies to this topic
#8956 MaximMini
MaximMini
  • 226 posts
Posted 13 February 2022 - 05:11 PM
Made use of the sunny but cold whether here and enjoyed the British Open on some amazing b roads :-)
#8957 Tones61
Tones61
  • 428 posts
Posted 13 February 2022 - 07:39 PM
Just doubled capacity of me compressor and have full constant pressure,
a 15kg butane tank 😃👍
#8958 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 14 February 2022 - 09:43 AM
Vizarded the last carb I bought. This is an HS4 coming from an Innocenti 90, with the horizontal elbow and big heat shield.
Throttle shaft halved, streamlined, and the butterfly knife-edged. Button screws are on the way.
Next task is now to build an offset airbox for it with motorbike air filter.
Get the red Mini running, have it insured and then it will be my Frankenstein, to test every mod I have and want to do on Toto the big project.
#8959 riktanius
riktanius
  • 233 posts
Posted 18 February 2022 - 05:24 AM
Got pics? Curious as to what you did... inno parts are easy for me to get.
#8960 Aaran13
Aaran13
  • 105 posts
Posted 18 February 2022 - 12:00 PM
Got it back from being MOT’d (passed and mostly clean bill of health) and rolling road Ed after the carb rebuild and Stage 1 fitted.
26350-CD4-5-C94-4-B5-F-81-F4-D99-A20-D40
Numbers don’t mean much to me if I’m honest and didn’t have a view of before the Stage 1 but a 10% uplift on my basic tune and drives great!
#8961 Aaran13
Aaran13
  • 105 posts
Posted 18 February 2022 - 12:01 PM
#8962 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 18 February 2022 - 12:17 PM
I'm lacking some knowledge here...
corrected and engine power OK.
Wheel power: is it the power coming to the wheels?
Drag power = losses?
That's a huge value, but I think usual for Minis?
Gilles
#8963 Aaran13
Aaran13
  • 105 posts
Posted 18 February 2022 - 02:29 PM
Gilles
I really should have asked when I was there… the Dyno is a MAHA LPS 3000 and having Googled the instructions am still no more informed. Hopefully someone will be along to put us straight!
#8964 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 18 February 2022 - 02:37 PM
Painted the garage floor while the car is in the shop
#8965 Mini Waco
Mini Waco
  • 438 posts
Posted 20 February 2022 - 02:36 PM
Finished the classic mini phone charger/base...  painted it in speedwell blue
Edited by Mini Waco, 20 February 2022 - 02:43 PM.
#8966 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 21 February 2022 - 08:42 AM
Here you go.
The HS4 for the Inno is basically the same, but the elbow and heat shield are different.
I disassembled everything and reshaped the throttle shaft (upper half cut away, new button screws cut to length, lower side thinned and streamlined, thottle butterfly cut edged):
I plan to build an offseted airbox to free a bit the space and have better access to the carb.
#8967 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 21 February 2022 - 08:51 AM
On project Frankie:
On Saturday, installed the rebuilt GMC167 Master cylinder back, plumbed the brakes.
Ahhh. and did the worst job ever. Pedal split pin...
Then reassembled the steering column, swore at the alignment to put the lower pinch bolt.
On Sunday: Bleed the brakes, the clutch, installed an RC40 exhaust, solved air leak at the carb.
loosen up the steering column and rack bolts, to sort a hard point in the steering. Still have to do the alignment.
Happy with the progress. Seeing the target of driving a Mini again coming closer :)
And should concentrate on the bodywork on Project Toto...
#8968 ads7
ads7
  • 351 posts
Posted 21 February 2022 - 10:11 AM
Cleaned the Carb. Transformed!😁Put car up for sale 😕
#8969 Quinlan minor
Quinlan minor
  • 1,169 posts
  • Local Club: LSMOC
Posted 23 February 2022 - 05:37 PM
Renewed my MOT with no issues on the car, other than the standard "The rear brakes tested quite low". I explained that, due to its light weight and short wheelbase, it isn't going to test at the same level as a Range Rover. I've driven a Mini with powerful rear brakes and, in the wet, on the road, switching ends is too exciting for me.
Not sure whether it's a Covid or crap summer effect, but my annual mileage was down by 73%. :(
#8970 Jasonc
Jasonc
  • 183 posts
Posted 24 February 2022 - 04:11 PM
Neglected the mini for the last couple of months, so thought I'd try starting it - No surprise it didn't start! Ordered new battery charger/maintainer and added service bits to my mini sport basket
    Bing (1)
