9720 replies to this topic
#8701 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 25 March 2021 - 12:55 PM
Managed to get my 2 x 8mm fuel lines on with the subframe in place. Pig of a job and makes me wish I had not chosen to go injection
#8702 Conradski
Conradski
  • 38 posts
  • Local Club: Hmmmm?
Posted 27 March 2021 - 02:21 PM
This weekend it will be:
-refit rear lights
-refit tank & pipes
-consider running engine with no exhaust to check it still fires up :-) :nuke:
-consider fitting new maniflow exhaust if a some welding can still be done with it in situ.
...feels too cold to spray paint the wing today :goaway:
Will post some pics and may even set up an Instagram with all the photos to date
#8703 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 27 March 2021 - 03:11 PM
FFD18-CBD-6-BCB-4752-9911-14-EA01-B3-D22
MOT...
#8704 ads7
ads7
  • 351 posts
Posted 27 March 2021 - 09:02 PM
Started strip down of Austin 1100 engine which turned over with a few squirts of plusgas down the bores and loosening of the mains/big end caps.
Initially looking quite good, off to my local engine shop to measure and see where we're at.
Quite enjoyed the grimy process
#8705 Lplus
Lplus
  • 887 posts
Posted 31 March 2021 - 08:27 PM
Finished refitting the clutch and tested it.  Yay!
#8706 Readers14
Readers14
  • 439 posts
Posted 31 March 2021 - 09:17 PM
Whilst the inlet & exhaust manifolds were out, I treated some rusty patches on the bulkhead with some Bilt Hamber Hydrate 80.
That stuff is amazing!
#8707 Cooperman
  • 23,273 posts
Posted 01 April 2021 - 03:46 PM
Cooperkid & I got the black 1990 Cooper road-rally car MoT'd and taxed for the first time since 2011.
#8708 SirBallD
SirBallD
  • 36 posts
Posted 01 April 2021 - 07:06 PM
Pulled the front subframe from my mini.
Removed all the dirt, gunk and primer to get a chance to evaluate the overall state.
Not a bad as first assumed.๐Ÿ˜
During evaluation I was thinking about enforcing the two jack points, by welding additional plates on.
#8709 GT Jimmy
GT Jimmy
  • 1,641 posts
  • Local Club: S.U.N.M.C
Posted 01 April 2021 - 08:16 PM
I finally wired in the Retrosound dab radio I got for my birthday, might have to have an early morning blast tomorrow to road test it
#8710 IronmanG
IronmanG
  • 1,228 posts
Posted 01 April 2021 - 09:49 PM
Started on a new loom.
#8711 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 02 April 2021 - 08:17 AM
A trip to Mill road garage on the Isle of Wight. Having used Ben for work carried out in the wifeโ€™s 40 LE, itโ€™s now time for our other mini to get some attention.
AC9-A4-F09-1819-4525-8-DE4-185-A7821-D96
On the ferry.......
BE36-FDA8-0-E59-4-EE7-8264-A57-B623-A3-E
#8712 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 April 2021 - 10:22 AM
On the ferry.......
It was great to see you both again!
#8713 Tones61
Tones61
  • 428 posts
Posted 02 April 2021 - 04:26 PM
Cam timing set using split lift at tdc,
Checked also on no1 inlet to be the same,
Also checked the old way using the tdc and timing disc/degrees,
Spun up on starter motor for 30 secs to 70 psi
๐Ÿš˜๐Ÿ‘
#8714 Tones61
Tones61
  • 428 posts
Posted 03 April 2021 - 05:45 PM
Some more spare engine add on's today,
45 weber,4.5 inch inlet,
Large bore maniflow stainless lcb,
๐Ÿ˜๐Ÿ‘
#8715 Readers14
Readers14
  • 439 posts
Posted 03 April 2021 - 06:25 PM
Fitted the exhaust brackets ready for the Maniflow system.
