9720 replies to this topic
#8656 Verderad
Verderad
  • 411 posts
Posted 02 March 2021 - 05:03 PM
Closed the bonnet gaps. Now just need to make it permanent with the welder. Amazing what patience and a whole day fettling wing, scuttle end, inner wing front panel makes
#8657 Steve_S
Steve_S
    Just On Tickover
  • 8 posts
Posted 02 March 2021 - 06:19 PM
Changed my cracked head for a 12g295. Awesome difference. If only I could change the cam without taking the engine out.
its difficult but possable
#8658 steeley
steeley
  • Just Joined
  • 623 posts
Posted 05 March 2021 - 04:59 PM
Fitted one of these to my Rvi rev counter which I could not get to work
It just replaces the existing electronics inside and is easy to fit
I haven’t tried it on the car yet as the engine is out (hopefully putting it back in tomorrow
But it has been checked and calibrated using instruction that came with it, so should all be good
https://spiyda.com/s...sion-board.html
Edited by steeley, 05 March 2021 - 09:25 PM.
#8659 Tones61
Tones61
  • 428 posts
Posted 05 March 2021 - 07:56 PM
Stripped out old diff to fit the output shafts and assemble into my MED X-pin diff,
Using this box for my spare race engine :-)
#8660 Tones61
Tones61
  • 428 posts
Posted 06 March 2021 - 03:25 PM
Modded cover with extra breather,cleaned and sprayed for my spare race engine :-)
#8661 Cooperman
  • 23,273 posts
Posted 06 March 2021 - 04:10 PM
Last week I found an early rocker cover which had that type of breather as standard. I might fit it onto my 1990 Cooper road-rally car sometime. You can't have too many breathers.
#8662 Readers14
Readers14
  • 439 posts
Posted 06 March 2021 - 06:27 PM
Adjusted the offside rear drum brake whilst the rear was on axle stands (waiting to fit Maniflow exhaust).
#8663 johnR
johnR
  • 2,297 posts
Posted 06 March 2021 - 07:07 PM
Started stripping the gearbox I re-built for my troublesome 1293 engine as I was having problems selecting 1st (had to go to 2nd then 1st to get it although not graunching) I presume it's not a baulk ring issue so will be checking selector.
#8664 1968andyf
1968andyf
  • 142 posts
Posted 06 March 2021 - 08:05 PM
Finished welding the cage in yesterday bolted the seats in and changed the oil nice fresh VR1 20/50
#8665 Brianm
Brianm
    Starting My Mini Up
  • 2 posts
Posted 06 March 2021 - 08:23 PM
Had the poser of inserting the Clevis pin and spring clip into the base of a clutch master cylinder I had just overhauled.
Having  the problem with similar on the brake master cylinder solved the problem as follows,
took a 6 inch length of copper brake pipe and hacksawed 1|2 inch down at right angles to the end, opened up with a small screwdriver, placed spring clip end on in the slot and clamped  it tight in the vice.
Lay across the car and inserted into end of clevis pin, depressed clutch to hold pin tight and. Moved copper tube lateral to release grip.
Quickest I have ever done one
#8666 Brianm
Brianm
    Starting My Mini Up
  • 2 posts
Posted 06 March 2021 - 08:25 PM
#8667 Jarvis_SPI
Jarvis_SPI
  • 53 posts
Posted 07 March 2021 - 12:47 PM
Strip down completed and bulkhead cross member treated with BH deox-GEL before it goes on the rollover  :thumbsup:
#8668 Tones61
Tones61
  • 428 posts
Posted 07 March 2021 - 04:30 PM
Cleaned,drilled,sprayed superleggera water pump pulley today for me spare race engine :-)
#8669 mrmeds
mrmeds
  • 249 posts
Posted 07 March 2021 - 05:02 PM
looked at it and cried...
#8670 petey81
petey81
  • 1,315 posts
Posted 07 March 2021 - 06:36 PM
Sorry to see the bad news. I cried for days after I hit a deer at 60mph!!!
