#8581
Posted 30 November 2020 - 08:53 AM
#8582
Posted 30 November 2020 - 04:59 PM
Fitted hi-los
I think more HI than low though.
I will give then a while then adjust down out of the clouds,
it looks like something off diesel brothers at the moment8F62D625-D1C9-4A71-AA25-491D5713BE0E.jpeg
nice one
#8583
Posted 01 December 2020 - 02:19 PM
#8584
Posted 01 December 2020 - 03:40 PM
And wrapped around cage at top instead of down to floor in eye bolts
Posted 02 December 2020 - 09:31 AM
#8586
Posted 02 December 2020 - 11:33 PM
Performed my first oil change on the mini since acquiring in July. Went with Castrol 20W50 (got it on special for $13/5 liters...bought two) and added a ZDDP additive. Fresh oil filter. Also did the valve clearances, replacing the rocker cover gasket with a freesh cork one, smeared with Hylomar Blue. The sump drain bolt was seeping, discovered it had a "dowty" rubberized washer which may have been reused too many times. Fittied new copper crush washer, smeared with PTFE thread sealant liquid. After a good long test drive today, no signs of any oil seeps at sump bolt or rockers.
I will say filling back fresh oil was quite a drawn out process. Had heard to be cautious not to pour in faster than it could drain down to sump, but didn't expect a 5 min wait for every 500 ml pour in! Must have a very small drain port!
Edited by Tornado99, 02 December 2020 - 11:36 PM.
#8587
Posted 05 December 2020 - 11:48 PM
Finished painting my engine block and put it back together - pretty much the last bit of engine bay tarting up I've been planning on doing since I got it in the summer, taking it out for a run tomorrow
Before:
After:
#8588
Posted 06 December 2020 - 09:11 AM
I just need to tidy up the headlight wiring. Next job is to wet sand then polish it up 😀
Posted 06 December 2020 - 09:33 AM
Before:
After:
Did you strip the engine bay, clean everything and put back together or clean it in situ? If in situ I'd like to know your method, cleaning tools/agents etc.
#8590
Posted 06 December 2020 - 09:34 AM
Car now resprayed and put back together.
It's looking great petey81 👍👍
#8591
Posted 06 December 2020 - 03:19 PM
Before:
After:
I did it mainly in situ - disconnected the battery then took off the HT leads, alternator, sump guard, air box and ignition coil.
Then lots of autoglym engine cleaner on the block, scrubbed with wire brush, cleaned off with a spray bottle of plain water and a rag, repeat until clean. Then took the spark plugs out to paint it, few coats of Halfords vht matte black with a normal paintbrush and a small art one to get all the gaps. Also painted the radiator housing and cap at the same time.
Cleaned off the plastic components with autoglym vinyl and rubber cleaner, including the fan while the alternator was off.
The alternator itself came up quite nice with just a dry wire brushing.
Rocker cover was cleaned with the same degreaser then normal primer and spray paint.
Obviously there's a couple of new parts between the photos as well - new radiator and hoses, silicone vacuum hoses and ignition coil (resistance was too low on the old one)
#8592
Posted 06 December 2020 - 05:06 PM
#8593
Posted 06 December 2020 - 05:27 PM
Posted 08 December 2020 - 10:48 AM
Clean MOT pass. Always nice
My old guy has retired so it was fun watching the young MOT'er groveling under the dash looking for the bonnet release.
#8595
Posted 08 December 2020 - 02:27 PM
Haha yeah that's always funny to watch 😁
6 user(s) are reading this topic
1 members, 3 guests, 0 anonymous users
Bing (2), AppleTango
