9719 replies to this topic
#8551 AndrewT
AndrewT
  • 147 posts
Posted 12 November 2020 - 04:34 PM
Wiring. Lots of it to get ready for installing the new engine.
Fused spur to convert to pre engaged starter motor, cut a new hole in the dashboard and fitted an oil pressure gauge as I want to make sure all is well before wrecking weeks of hard work. Tidied up some historic wiring 'fixes' whilst I was at it.
All very satisfying as no major problems occurred.
#8552 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 12 November 2020 - 05:12 PM
Dry fitted the petrol tank. Adjusted near side door
#8553 whistler
whistler
  • 1,788 posts
Posted 12 November 2020 - 05:15 PM
Did a couple of bad tack welds to new full floor pan.
#8554 slowy
slowy
  • 71 posts
Posted 12 November 2020 - 05:42 PM
Rubbed down fibreglass dash for spraying.
#8555 T5FAU
T5FAU
  • 31 posts
Posted 13 November 2020 - 03:59 PM
Filled in more daylight holes with fresh metal
#8556 IronmanG
IronmanG
  • 1,228 posts
Posted 13 November 2020 - 04:27 PM
Handbrake.
Ordered some new wheels and yokos.
Very excited
#8557 Tones61
Tones61
  • 428 posts
Posted 13 November 2020 - 04:40 PM
A couple of choice stickers ??
MED parts inside ?
Edited by Tones61, 14 November 2020 - 10:20 AM.
#8558 84sprite
84sprite
  • Just Joined
  • 55 posts
Posted 14 November 2020 - 01:07 PM
Hi Surfblue
They match the body colour.. body is new Mazda red (46V)
Attached File  image27.jpg   59.42K   0 downloads
Edited by 84sprite, 14 November 2020 - 01:26 PM.
#8559 Sheep 1161
Sheep 1161
  • 15 posts
Posted 14 November 2020 - 03:55 PM
Made a frame to stop the body from moving/twisting, it is now on it's side with half the floor missing now time for some triming and prep in the hope the replacement floor fits.
#8560 Tones61
Tones61
  • 428 posts
Posted 15 November 2020 - 04:03 PM
Fitted kermits to the green racer,
And a little handbrake raiser bracket for more clearance between lever and internal gear linkage,
#8561 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 15 November 2020 - 05:45 PM
Not today...but yesterday.
Spent 30mins fitting a new CSI Dizzy. So easy to set up, a joy to do.
Just got to do a few test drives to see what Curve is best.
DickyB.
#8562 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 22 November 2020 - 01:42 PM
Cleaned carbs. I now have 3 HS4 and one HS6 in the man's cave.
Think it's enough for a Mini? :)
The plan is to Vizard one of them, rebuild and test (one day when the car is rolling...)
And started another side project:
My plan is to create a custom airbox, having the air intake behind the grille, the air filter somewhere close to it, and the airbox on the carb with the stub stack.
Stubstack and airbox could be made out of plastic 3D printing or GFRP.
Just do not have any idea of the available space for the whole system...
#8563 Tones61
Tones61
  • 428 posts
Posted 22 November 2020 - 08:48 PM
Made up and welded breather onto my new rocker cover,
Primed,sprayed,lacquered,
Fitted to race mini with obligortary decal ??
#8564 Tornado99
Tornado99
  • 750 posts
Posted 24 November 2020 - 12:41 AM
Pulled the wiper motor and cable out to see if I could improve the little to no higher wipe speed feature.
Connectors were a wee bit corroded so cleaned them as best I could. Used a bit of rust converted gel solution on the terminals followed by flushing off with brake cleaner. Cleaned and regreased cable. Took motor casing apart and cleaned out, put fresh grease. Got it all back together and on car. Two speeds are now there! LUXURY!!
#8565 MiNiKiN
MiNiKiN
  • 198 posts
Posted 24 November 2020 - 10:28 AM
Finished porting the head yesterday - turned out really nice.
5 user(s) are reading this topic
    Bing (3)
