New throttle & choke cables fitted during my lunch break
#8446
Posted 24 June 2020 - 11:32 AM
#8447
Posted 24 June 2020 - 05:16 PM
MOT success!
#8448
Posted 24 June 2020 - 07:02 PM
load bed sprayed, interior sprayed. Hopefully by the end of the week it should be all done except the roof!
#8449
Posted 25 June 2020 - 06:54 AM
998 carb Vizardification, Well worth doing, noticed better throttle response and pulls a little harder, and free! if you got a file/dremel that is....
Posted 25 June 2020 - 04:09 PM
#8451
Posted 25 June 2020 - 08:15 PM
Started to make further repairs patches, this time for the rear valance.
On the good side, it fits nearly perfectly to the area I cut out.
On the not so good side: I didn't took measurements before cutting out. Happy to have the body to take some measurements and a spare new valance. None does really match haha...
Will do two tack welds and present the valance on the car tommorow.
#8452
Posted 25 June 2020 - 09:10 PM
Like to know more information on the vizardifican of the carbie. Any posts on it.
It's quite easy to do, if you buy David vizards tuning the a series engine it's all in there. The long and short of it is remove the carb, remove the butterfly to allow removal of the spindle, then remove material as I did. You leave material around the countersink on the top side and thin out the bottom leaving a few threads. I finish mine with emery cloth of varying thickness to produce an aerofoil shape. Would advice if you do it protect the two ends of the spindle that located into the carb body else you'll get air leaks. Also loctite the screws in place and trim the excess threads left by the screws
#8453
Posted 26 June 2020 - 06:22 AM
#8455
Posted 26 June 2020 - 05:33 PM
Ohhh cool picture !!
Made my four Group 2 arches from the mold my father has.
Received my Leyland boot badge Mini 1000.
Made my repair on the rear valance.
Efficient day!!
#8456
Posted 26 June 2020 - 06:31 PM
#8457
Posted 26 June 2020 - 09:13 PM
Just identified and fixed an annoying squeak from the front today.
#8458
Posted 28 June 2020 - 08:25 PM
Shooter
#8459
Posted 29 June 2020 - 03:38 PM
