9970 replies to this topic
#8416 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 08 June 2020 - 05:42 PM
wooooo hooooo mini past MOT no advisory's not even a mention of emission. bloody strange how it varies from garage to garage. anyway very happy can get it back out and enjoy it... on another note ordered a new fuel sender unit as its not worked for ages, whipped the old one out and the float is full of petrol... that would do it. New one on the way so for the first time in ages I wont have to keep dipping the tank!
It depends on the tester and how good they are with their tools ?
#8417 ClassicAsh
ClassicAsh
  • 139 posts
Posted 08 June 2020 - 05:44 PM
yes you are right about that, this guy said all SPI seem to struggle but he has the knowledge lol. Better than the last place that's for sure.
#8418 Quinlan minor
Quinlan minor
  • 1,377 posts
Posted 08 June 2020 - 06:34 PM
The rheostat had failed on mine, you could have had my old float.
#8419 gdcarpenter
gdcarpenter
  • Just Joined
  • 43 posts
Posted 08 June 2020 - 07:05 PM
1990 Mini Mayfair 1000 Japanese Spec Cooper Conversion: Time for steering column bushings.
Wouldn't you know it, bolt that holds column shaft to Steering rack broke off inside coupler! AARGH!
No room for a drift punch, tried clamping vice grips as tight as possible to threaded end sticking out and hammering away, no go.
Eventually wound up forcing the clamp section apart enough to finally remove the shaft.
Went out and got a grade 8 bolt as a replace the broken bolt.
Nice tight steering now.
#8420 AndrewT
AndrewT
  • 147 posts
Posted 10 June 2020 - 05:26 PM
Despite being sat in the garage unused for two years it passed its MOT first time today.
Now got the fun task of registering it with DVLA.
#8421 Quinlan minor
Quinlan minor
  • 1,377 posts
Posted 11 June 2020 - 12:54 PM
Changed out my old fuel tank sender for a new one. The old one had worn through the wire on the rheostat.
#8422 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 11 June 2020 - 06:25 PM
Looked at in primer and sold a load of stuff on ebay. Want it back from the shop to start putting it back together!
#8423 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 12 June 2020 - 02:14 PM
Finished up early at work today, so went and took the rear subframe out.
Have the car ar works so I've been spraying penetrating fluid on all the bolts the last week.  Only snapped one.
#8424 evilpen14
evilpen14
  • 115 posts
  • Local Club: CCC and RAF Mini Club
Posted 12 June 2020 - 06:22 PM
Well I serviced e her yesterday and couldn't figure out what I did for the engine to fail to start. This morning I found the problem and it was a loose connection to the coil.
#8425 PiG
PiG
  • 144 posts
Posted 13 June 2020 - 08:50 AM
Finally making some progress after 7 years so far!  40th LE in Island Blue.
Body stripped and it's off for blasting and etch primer next.  It will now reside where my son is doing his classic car restoration apprenticeship with an Austin 7 specialist restorer.  This is the first project car for his spare time and I can go there and work on it too.  He is then after his own mini for when he turns 17 next year after having learned on this one!
Subframes off and ready to be stripped down and go for blasting/powder coating.
Been working on the engine and gearbox for some time now also, that's almost complete now, going 1330, Swiftune cam, MED 1.3 rockers, duplex, AC Dodd head, rebuilt box with a lot of new uprated Guessworks parts, windage tray and 3.2FD, crosspin diff etc.
Edited by PiG, 13 June 2020 - 08:51 AM.
#8426 S.Willson
S.Willson
  • 31 posts
Posted 13 June 2020 - 12:39 PM
Create a temporary makeshift sun/rain shade (until I can afford a garage!), cleaned and polished and added the L2B NHS sticker!
#8427 Ol timer
Ol timer
  • 331 posts
Posted 13 June 2020 - 06:32 PM
Wash and waxed both toys
And of course its starts to rain
#8428 PiG
PiG
  • 144 posts
Posted 14 June 2020 - 08:53 AM
Amazing how even an mx5 looks big compared to a mini!
#8429 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 15 June 2020 - 07:10 AM
I hope the RS6 is strong enough to tow a trailer and a Mini Shell on it ;)
I did a bargain yesterday, although not compatible with my Mini:
About 120 pounds for both. They look to be in good shape, maybe a little welding on the rear to do.
By the way, is the rear one specific to the mk1-3 or can I put it on a later shell?
AFAIK are only the front trunnions the smaller type, can they be changed to later models?
#8430 Verderad
Verderad
  • 413 posts
Posted 15 June 2020 - 11:41 AM
Fixed the end of the lower dash rail, spent far too long shaping a replacement end, then decided just to get it welded in.
All ready now to add brackets on to A Post closer.
Having spent a day managing 4 inches of weld, I can see why im 2 years into Resto, just the doors and the roof left
