9722 replies to this topic
#8356 Big Sam
Big Sam
  • 853 posts
Posted 02 May 2020 - 04:47 PM
Steering column removed, as well as clutch master cylinder. All i need now is the pedal box out and its a bare shell.
#8357 siemac
siemac
    Starting My Mini Up
  • 1 posts
Posted 02 May 2020 - 06:54 PM
Replaced the manifold gasket ( found out that my PTC heater was shot, so now added to the list of bits needed lol).
Started to go through the birds nest of a wiring loom as the battery drains flat when its left.
On that subject can anyone offer any advice on what this may have been fitted and connected to.
#8358 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 02 May 2020 - 08:24 PM
Continued removing Austin-Rovers finest seam sealer to uncover more holes.
#8359 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 02 May 2020 - 11:05 PM
Built the rear and driver's side engine mounts for my Cg10 engine conversion
#8360 Tda321
Tda321
  • Just Joined
  • 28 posts
Posted 02 May 2020 - 11:41 PM
Finally got her running again after a head gasket replacement which has been delayed by the dreaded COVID! Time to get tax sorted and she can take me to and from work again!
#8361 blackbelt1990
blackbelt1990
  • 2,614 posts
  • Local Club: Minimus Maximus
Posted 08 May 2020 - 08:24 PM
Been cracking on with getting my loom in!
#8362 Shooter63
Shooter63
  • 1,025 posts
Posted 09 May 2020 - 08:43 AM
Took the Mk1 out for an essential shopping trip, unfortunately got lost so ended up traveling around most of Essex looking for a shop that sold green fag papers, also topped up the battery by driving it
Shooter
#8363 Big Sam
Big Sam
  • 853 posts
Posted 10 May 2020 - 11:07 AM
Got the mini up on the jig yesterday, more bracing and floor out to do.
#8364 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 11 May 2020 - 07:54 PM
Refitted my dash liners and light unit I made.
#8365 Algordo1100
Algordo1100
  • 774 posts
Posted 12 May 2020 - 07:39 PM
Got a few laps in.
#8366 paul50
paul50
  • 86 posts
Posted 12 May 2020 - 07:59 PM
Done a oil and filter change. Went to petrol station
#8367 Chris.Williams
Chris.Williams
  • 679 posts
Posted 14 May 2020 - 08:13 PM
Took delivery of my S block ?
Attached File  24847554-BD9C-4E4B-BF54-1D35BAA88923.jpeg   73.48K   2 downloads
Attached File  1D998572-15E9-47E9-8DC2-D06E5659F53A.jpeg   85.43K   4 downloads
Came with a set of rods, wasn’t expecting that
Attached File  7850C07B-7A1C-4B86-98EB-BC2F94560728.jpeg   114.31K   3 downloads
Attached File  718A10C0-E385-4B01-ACF5-A4F7BC304B56.jpeg   71.29K   2 downloads
Hunting down a crank now ??
#8368 Big Sam
Big Sam
  • 853 posts
Posted 15 May 2020 - 04:41 PM
Made some brackets to bolt into the seat mounts on the front of the crossmember so then be welding to the bracing so i can cut the floor out.
#8369 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 16 May 2020 - 05:07 PM
Working om my mini I bought back from the guy I sold it to. Been sat in a dry barn for some years. Not much rust, but a lot to go over.
-Put together one side of the suspension with new red dots, modded hilos and new knuckle.
-Cleaned up disk and mounted refurbuished caliper and new pads.
-welded on capitive nut on bottom rad bracket, mounted rad and new pipes.
-Oil filter change change
-Checked fuel delivery to carb ok.
-Tried to start, would just fire on start gass, so carb must be blocked. Least I know that the igntion side is working. Good oil pressure
-Found water pipling out of the waterpump hole, so another thing to fix.
Edited by no66, 16 May 2020 - 05:10 PM.
#8370 leepol83
leepol83
  • 1,744 posts
Posted 16 May 2020 - 08:57 PM
Tintable raptored the boot, top tip don’t panel wipe with you’re head in the boot too long WOW!!!!! ?
