#8311
Posted 28 March 2020 - 11:25 PM
#8312
Posted 29 March 2020 - 10:17 AM
Removed the old clutch master cylinder and have decided to replace it as it looks to worn to sort.
Posted 29 March 2020 - 10:47 AM
Welding. Again. And again,
Made the repair on the lower flitch panel.
One step closer to put the new floor back in place.
Next step is to finish the repair patch for the companion bin closer.
#8315
Posted 30 March 2020 - 11:09 AM
#8316
Posted 30 March 2020 - 11:10 AM
#8317
Posted 05 April 2020 - 02:19 PM
Posted 05 April 2020 - 05:11 PM
#8319
Posted 07 April 2020 - 10:59 AM
Turned it on... Off.
Decided it was much too loud (96db@2m) so this happened:
It now has the compressor in an insulated box with sound barriers made of foam and air filters. It also has an integrated ventilation system now. ?
Only produces 63db@2m now, not perfect but WAY better. Need to clear the garage now so I can actually do some work on the mini, which was the whole point of this project... ?
#8320
Posted 07 April 2020 - 11:11 PM
Decided against it, swept up and left.
#8321
Posted 14 April 2020 - 04:50 PM
Posted 14 April 2020 - 05:20 PM
looks goodLittle mod today,alloy heat shield ✌
#8323
Posted 15 April 2020 - 12:05 AM
Head is off at the machine shop for valve seats, so doing some minor tidy ups while the car is off the road.
1. Painted the rocker cover and thermostat housing
IMG_0209.JPG 85.62K
1 downloads
2. Changed the steady bar bushes - bulkhead bolt was rusted to sleeve so had to drill the head off and then lever the bush out.
3. Painted the filler neck and replaced the neck seal
IMG_1939.jpg 76.95K
0 downloads
4. Cut radiator threaded bushes down
The car came with this aluminium rad and only two shroud to rad bolts had been fitted. Turned out that the rad was 10 mm bigger than the shroud, so I sawed 5 mm off each bush on the front and rear. Shroud now fits properly.
IMG_1936.jpg 120.16K
0 downloads
5. Removed and cleaned the fan. Glad I did as it was fitted the wrong way round!
#8324
Posted 15 April 2020 - 12:24 AM
Started on flat floor MK4
#8325
Posted 15 April 2020 - 04:15 PM
I wonder how many horsepowers I've lost without the stripes ;)
