9722 replies to this topic
#8221 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 26 November 2019 - 05:22 PM
Got the original wheels back from having them refurbished.
Really pleased. Shame it seems like a long time before I can fit them........so many jobs to do.
#8222 mikewantsamk1
mikewantsamk1
  • 15 posts
Posted 30 November 2019 - 06:34 PM
Not to my mini but recycled an old frame and made this!
Attached File  Screen Shot 2019-11-30 at 18.28.28.png   542.34K   0 downloads
#8223 Tones61
Tones61
  • 428 posts
Posted 30 November 2019 - 07:50 PM
Weighed my friend gavins mini on my home scales ftw :-)
Nice scales, beats my set up using 6 sets of cheap bathroom scales!
What was your total weight and specs please dude
#8224 imack
imack
  • 2,104 posts
Posted 30 November 2019 - 08:42 PM
Total weight is about 650 kgs with 1/2 tank of fuel ( twin 5.5 gallon tanks ) and spare wheel.
Fronts 200kg per corner, rears 125kg per corner. Weights within 2-3 kgs across axles - very easy to set up with the old Ripspeed hilo's with the long allen key adjusters.
All steel shell, standard subframes, rubber suspension, 5 port A series, standard glass, standard battery location. Old safety devices 6 point cage, fibre glass bucket seat, no carpets, rear seat or passenger seat. All other interior trim fitted.
#8225 GT Jimmy
GT Jimmy
  • 1,642 posts
  • Local Club: S.U.N.M.C
Posted 04 December 2019 - 07:03 PM
Put the doors on
#8226 Shooter63
Shooter63
  • 1,025 posts
Posted 15 December 2019 - 03:03 PM
Fitted a new master cylinder, bled the brakes, fitted new door seals and Hinge seals, and re-built the carb
Shooter
#8227 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 15 December 2019 - 03:21 PM
Lost motivation on mine for now, ruddy weather is hampering everything when I muster up motivation to do something it rains.....
#8228 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 16 December 2019 - 09:35 AM
Removed all the sound deading yesterday least that's out the way amazing how much was on the floor quite a weight
#8229 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 16 December 2019 - 10:03 AM
Bought 3 carbs for 60€. One older HS4, one newer HS4, one HS6.
Dismantled both HS4 and cleaned them in my ultrasonic bath, works a treat!!
Then I spent a little time to polish the dash pots to make them a little bit shinier.
This evening it's time to swim for the HS6.
And maybe my 12G295 in citric acid bath to remove the rust.
#8230 need4speed
need4speed
  • 83 posts
Posted 16 December 2019 - 06:36 PM
I cleaned the old gaskets off between the block and the gearbox, fitted a new oil pump and clutch release bearing.
#8231 need4speed
need4speed
  • 83 posts
Posted 18 December 2019 - 08:09 AM
New bearings and primary oil seal fitted to the new flywheel cover
#8232 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 21 December 2019 - 11:01 PM
Not today but the last time I worked on my car the other week. At the beginning of the night just the gear box and block were present.
Attached File  20191126_100002_resized.jpg   71.25K   1 downloads
#8233 S.Willson
S.Willson
  • 31 posts
Posted 27 December 2019 - 04:07 PM
Over the last few weeks been tinkering - fitted a cup holder for my morning coffee. Adjusted hilos, replace the rubber subframe mounts to solid ones, replaced the wipers, unclogged the jet nozzles, replaced the side repeater lens as they were no longer clear! Next up replace all four tyres and tracking! Anyone interested in knowing how the cup holder was fitted let me know (only one small drill hole in the metal frame below the dash)
#8234 Norfolk Boy
Norfolk Boy
  • Just Joined
  • 130 posts
Posted 27 December 2019 - 04:16 PM
Would you have a link to the cup holder please. Looks great and you’ve been busy, top work ?
#8235 S.Willson
S.Willson
  • 31 posts
Posted 27 December 2019 - 04:28 PM
The cup hold is from eBay:
https://rover.ebay.c...tm/133197086980
It holds a bottle like the one in the picture, not sure about takeaway coffee cups from costa, Caffè Nero etc! I have a reusable coffee flask.
I added the brackets they’re from B&Q!
