9722 replies to this topic
#8206 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 20 November 2019 - 05:37 PM
Took apart the front grill to refurbish it.
i carefully numbered each Crome rail as I removed it.
when I started to clean it I found that each piece was stamped with a sequential number.......
Great detail, and marvellous help for reconstruction
Top marks Rover???
#8207 Tones61
Tones61
  • 428 posts
Posted 20 November 2019 - 05:54 PM
I was in search of the solution to no drive (in any gear) and a clattering from "down there". (not my car so I don't know how it happened). So I dropped the subframe etc. out and took the flywheel off (Minispares puller - piece of cake.. thanks). The clutch is fine. Oh dear, something broken in the box or diff. Last time I stripped one of those was about 1977.
Now I've got as far as the drop gears and the first motion shaft gear retaining nut has unwound itself against the flywheel housing bearing, chewing the aluminium somewhat. There's no sign of a lock washer for the nut - should there be? It's getting more messy by the day.
Hi mate,just googled pics,looks like there should be a locking washer with bend over tabs :-)
#8208 need4speed
need4speed
  • 83 posts
Posted 21 November 2019 - 11:11 AM
I'm looking at the oil pump on my 1275 A plus and it is bolted in with two hex head and two philips head bolts. Is this normal?
#8209 GraemeC
GraemeC
  • 7,438 posts
Posted 21 November 2019 - 11:32 AM
Yes.
Only the hex heads fasten it to the block. The philips hold it together.
#8210 need4speed
need4speed
  • 83 posts
Posted 21 November 2019 - 12:21 PM
Yes.
thanks
#8211 Tones61
Tones61
  • 428 posts
Posted 24 November 2019 - 02:41 PM
Fitted grille buttons to my mpi :-)
#8212 Tones61
Tones61
  • 428 posts
Posted 24 November 2019 - 02:43 PM
Weighed my friend gavins mini on my home scales ftw :-)
#8213 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 24 November 2019 - 02:53 PM
Started to remove the bitumen on the floor is a heat gun and scaper the best way?
#8214 panky
panky
  • 1,790 posts
Posted 24 November 2019 - 03:14 PM
Just try the scraper or an old wood chisel first. It's usually very brittle and comes off in chunks with a good poke.
#8215 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 24 November 2019 - 04:39 PM
Cheers pal
#8216 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 24 November 2019 - 04:40 PM
Cheers pal
Edited by Bdshim, 24 November 2019 - 04:41 PM.
#8217 imack
imack
  • 2,104 posts
Posted 24 November 2019 - 06:04 PM
Nice scales, beats my set up using 6 sets of cheap bathroom scales!
Edited by imack, 24 November 2019 - 06:05 PM.
#8218 Tones61
Tones61
  • 428 posts
Posted 24 November 2019 - 07:10 PM
Bought mine off eBay, X4 of 300 kg each, £134 posted
Made ramps from left over wood from diy work
#8219 JXC Mini GT
JXC Mini GT
  • 842 posts
Posted 25 November 2019 - 01:42 PM
Took my Mini on a 106 mile trip to Mill Road Garage for Ben to work his magic, the weather conditions were dreadful but it was such an enjoyable drive, definitely put a smile on my face.
I do love my Mini.
#8220 cooperd70
cooperd70
  • 726 posts
Posted 25 November 2019 - 02:50 PM
I do love my Mini.
Can't wait to see resto pics from BenO ?
Edited by cooperd70, 25 November 2019 - 02:51 PM.
