#8116
Posted 29 August 2019 - 11:03 AM
#8117
Posted 29 August 2019 - 07:42 PM
Fixed the rear fog light illumination - in line fuse was not seated properly.
Bought a ball joint splitter & ball joint kit ready for this weekends job!
#8118
Posted 30 August 2019 - 03:16 PM
Took off the hose at jets & reservoir ends and blew compressed air down it. That seemed to clear the blockage!
Started to remove the old ball joint in preparation for fitting new one.
#8119
Posted 31 August 2019 - 04:10 PM
First time I’d replaced one, so had to consult this YouTube vid: https://m.youtube.co...h?v=JtHHfkHTPZs
Went fairly straight forward. Only time consuming part was figuring out how many shims to use (tightening, checking play, untightening, fitting more shims, tightening and repeat!)
#8120
Posted 04 September 2019 - 08:01 PM
Removed the manifold nuts and lifted the inlet manifold out the way (those 2 inner nuts are a nightmare to get to!)
#8121
Posted 04 September 2019 - 09:10 PM
I stared intently at the engine, touched a few hoses, then went on the internet to find out what it all meant
#8122
Posted 05 September 2019 - 08:18 PM
Removed the old manifold gasket. I can see why it was blowing now. There was nothing left of it on one corner!
Edited by Readers14, 06 September 2019 - 03:31 PM.
#8123
Posted 07 September 2019 - 01:55 AM
Yip, that’ll do it.Dropped exhaust off the brackets to move the manifold away from the studs.
#8124
Posted 08 September 2019 - 07:40 PM
Welded cracked toeboard, fitted front subframe rear mounts to the now repaired and also now reinforced toeboard. Strengthened upper engine steady bracket (the bracket that's on left of bulkhead under brake servo). Welded captive nuts to front subframe for mounting the sump guard, should make life easier when changing oil in future. Sorted oil leak from sump plug, was only a little weapy but was enough to pisd me off ?
Started to paint front subframe, ready to be rebuilt with everything that was removed. Fitted pit stand mounts to O/S sill, also reinforced around that area to enable use of them.
#8125
Posted 08 September 2019 - 08:34 PM
Posted 09 September 2019 - 12:09 PM
Swapped the mkIV taillights with mkII/III taillights. Changed the passenger side rear shock while the tank had been moved. Need to buy another shock and replace the driver's side rear shock next.
#8127
Posted 10 September 2019 - 06:17 PM
#8128
Posted 10 September 2019 - 06:52 PM
The previous owner had left it in & not not bothered to fix it.
Bought a stud extractor, as mole grips weren’t working.
These stud extractors are awesome! It pulled out some stubborn rusted studs.
Edited by Readers14, 10 September 2019 - 06:53 PM.
#8129
Posted 13 September 2019 - 06:54 AM
Fitted new manifold gasket and shiny new stainless manifold studs/nuts - no more seized studs! (I hope!!)
#8130
Posted 13 September 2019 - 07:08 PM
