#8086
Posted 16 August 2019 - 10:56 AM
#8087
Posted 17 August 2019 - 08:55 AM
#8088
Posted 17 August 2019 - 08:14 PM
..... is not having an oil leak a failure!!!!
Yes! Every Mini should have one!?
#8089
Posted 18 August 2019 - 01:22 AM
Moved the choke from the bracket next to the column to the switch panel. Added the heater control in anticipation of actually getting a heater - other end just held in place with cable tie. Drilled out the old choke bracket to fit a Lucas switch for the washers. Moved the stereo, wired it in to the ignition and fitted a new aerial.
#8090
Posted 18 August 2019 - 08:28 AM
Shame my car isn’t fast enough to need the extra cooling!
#8091
Posted 18 August 2019 - 06:56 PM
#8092
Posted 19 August 2019 - 12:37 AM
Had a builder mate knock up some shelves to aid in the organisation of my crap, I mean, valuable collection of historic mini parts
Quite organized and looks good....
#8093
Posted 21 August 2019 - 01:19 PM
Pulled up a chair in front of him, sat down, and just admired it.:)
#8094
Posted 21 August 2019 - 04:47 PM
Adjusted washer jets so the spray actually hits the screen!
Cleaned up electrical contacts on the tail lights/ brake lights.
Next up is:-
Free up the nearside seatbelt - seems to be jammed at the moment.
Free up the offside rear drum brake
And replace nearside upper ball joint - not looking forward to this one as I’ve never done one before.
Also suspect the battery is on its way out as the engine is becoming increasingly harder to start. Will probably check the fan belt tension to see if the alternator is actually charging the system.
#8095
Posted 22 August 2019 - 08:52 AM
#8096
Posted 22 August 2019 - 10:36 AM
Ordered more paint for front subframe.... ?
Painted rocker cover....
Cleaned many many parts....
Getting ready to rebuild front subframe and engine ready to be mated together...
#8097
Posted 22 August 2019 - 11:20 AM
Up at 5 this morning to finish fitting an MED ST1 ultra light flywheel kit ... what a difference! The Verto assembly is never going to be truly light weight but the difference is more due to the fact that it's properly balanced which has transformed the feel all through the rev range. Very pleased and much better with an oil free clutch plate!
#8098
Posted 23 August 2019 - 01:28 PM
Absolutely nothing! The joys of being a new home owner...
#8099
Posted 24 August 2019 - 12:19 PM
Posted 24 August 2019 - 02:38 PM
That's interesting, a Morris badge and Austin Cooper grille! Nice colour by the way... looks like 'Maroon B'...?
Edited by WMU 211G, 24 August 2019 - 02:39 PM.
